Author Topic: Steering Wheel Puller  (Read 1349 times)
Craig_R
  • Watford
« on: 09 August 2007, 20:18:00 »
Ahhhhhhhhhhh I cant get my Steering Wheel Back Off
I took it off last weekend to do some checks got it off by putting my knees behind it and hitting the center with a hammer and it popped off no problems. But in putting it back on I was Rushed By The GF to go out and i put it back on not stright Total Bu**er and Now I cant get it back off to put it back on straight and i have hit it over and over with a hammer but no movment at all Grrrrr and i have knacked the nut from hitting it with the hammer that needs replacing.
I think I need a Steering Wheel Puller Does anyone have one ?
Craig
Mod's
[To be Fitted]Reverse Sensors
Re: Steering Wheel Puller
« Reply #1 on: 09 August 2007, 22:52:55 »
Craig
Sorry No! But there's one here if you get stuck. Careful you don't burr over the end of the steering column when you're hitting it.
Pete Elite
  • Uxbridge, Middlesex
« Reply #2 on: 10 August 2007, 00:16:17 »
Craig
 Hi Craig,
            If i were you i would refrain from hitting the column with a HAMMER as i read on here somewhere that the column is made to colapse in an accident and could be damaged by heavy impacts :o.
 I'm sure someone on here can verify this in more detail.
    Hope this helps,
                          Pete :y.
Craig_R
  • Watford
« Reply #3 on: 10 August 2007, 10:22:08 »
Yep I know This Is why I Stopped I did not want to totally knack it as i have to drive 500 miles this weekend so ill sort it when i get back Ill just have to have a steering wheel that is not stright for the mo
Mod's
