Author Topic: Power/Fuel drop  (Read 1646 times)
Erthe
  • Berwickshire, Scotland
Power/Fuel drop
« on: 09 August 2007, 09:08:47 »
Ok, a strange one for me but I am sure that someone out there will have a suggestion  :-/
There is one bend on my way to work where I slow down from 60mph to about 20 for a tight left hand bend. Recently my miggy has started to drop power as I am coming round the bend. It is as if she is starved of full fuel for about a second and then she picks up as normal and all is well again. This happens nearly every time I take that bend and I have never noticed it at any other time.
Yes, there is plenty of fuel in her (not running on fumes)
It was suggested that it may be a clogged up fuel filter...I put a new one on yesterday but it still happened this morning on my way into work. (The "How to" made it so easy  :y :y)
any suggestions?
Dave
DaveL
  • Nr. Cupar, Kingdom of Fife
Re: Power/Fuel drop
« Reply #1 on: 09 August 2007, 11:04:05 »
Could be crud inside tank blocking fuel pick up pipe to pump.
DaveL
Dazzler
  • Haverhill, Suffolk
Re: Power/Fuel drop
« Reply #2 on: 09 August 2007, 20:18:39 »
Have you checked the pump pipes at the tank, to make sure that they are not perishing/leaking???? I mean via the access hole in the boot via a round removable panel ;)
Erthe
Re: Power/Fuel drop
« Reply #3 on: 10 August 2007, 09:48:04 »
Thx guys, I have checked the pump pipes and all seems as it should be.  :y
If it is crud in the tank, what options do I have? what is the easiest way to resolve this?
Dave
Danny
  • Wigan, Greater Manchester
Re: Power/Fuel drop
« Reply #4 on: 10 August 2007, 13:16:52 »
with these suggestions of crud in the tank or leaky pipes.. wouldnt the fuel/power drop be evident at different speeds? not just on this one bend?
