Author Topic: OMEGA 99 T reg Replace Front Pads  (Read 1286 times)
moggy74
  • Hinckley
« on: 10 August 2007, 13:33:10 »
HI,
   Just a quick one,plan to do front pads on my 2 litre omega over the weekend,looks straightforward is it????????
Thanks
e mail colin.mogford@uk.gm.com
Markjay
  • London
Re: OMEGA 99 T reg Replace Front Pads
« Reply #1 on: 10 August 2007, 13:41:20 »
Yes it is.
You get some idea here:
http://www.omegaowners.com/forum/YaBB.pl?num=1175890350
Thing to remember is when pushing the piston back (preferably using the proper tool for it) you should also open the bleed nipple and let the brakes bleed - otherwise you could end-up with air pushed into the ABS unit. Now this does not happen very often, but when it does then you need a visit to a Vauxhall dealer to bleed the ABS.
« Last Edit: 10 August 2007, 13:55:33 by markjay »
Alas, no more Omegas....
jonathanh
  • coventry
« Reply #2 on: 10 August 2007, 15:05:44 »
and make sure that you get the correct disk/pads. the 2 ltr had a different, slightly smaller version on some cars.
You'll also need pad wear sensors - invariably they break off in the old pad
« Reply #3 on: 10 August 2007, 15:25:37 »
a 99T should take same pads as V6 - its the pre 97 2.0l that had smaller ones.
