Author Topic: Cooling Fan Problems 99 Omega 2.0 Auto  (Read 1926 times)
fast_pug
  • Warrington
« on: 09 August 2007, 22:23:23 »
Hi all I have had a quick look to see if anyone has had this problem before couldnt see anything but sorry if it has already been posted anyway ----
Bought a Vauxhall Omega on a 99 S plate its a 2.0 auto with AC bit of a strange problem well strange to me might be a common problem not upto date with these cars.
First of all no AC on after running for 15 - 20 mins warning light on the temp gauge comes on at over 100 switch the AC on it cools down??? Both fans kick in
Secondly should both fans come on by switching the AC button or just the AC fan?
It's not really a massive problem I'll just drive with the AC on but not good on the old wallet
Temp gauge sits just over 95
Head gasket is fine no real signs of over heating in the past & when I bought it the fan kicked in on its own not doing that now
Checked the fuses all the obvious stuff
Thanks inadvance for any info
Fast_pug
Re: Cooling Fan Problems 99 Omega 2.0 Auto
« Reply #1 on: 09 August 2007, 22:29:36 »
I suspect the radiator fan is not coming on when the coolant temperature rises. Running the AC means the fan(s) run continuously so that saves it from overheating.
Have a look in the relay box near the battery for any blown fuses.
Fan switch is on the radiator under the top hose. I guess it's possible that this has died.
Do the fans both turn freely by hand?
« Reply #2 on: 10 August 2007, 09:09:36 »
Agree, if its going up to dangerous temps (100C) then the fans carn't be kicking in.  Temp switch in rad may be faulty
fast_pug
  • Warrington
« Reply #3 on: 10 August 2007, 10:35:25 »
Hi yeah both fans turn freely by hand I've checked the fuses seem ok I chance the fan switch hopefully that will help
Thanks great help
Fast_pug
« Reply #4 on: 10 August 2007, 12:20:29 »
unplug temp sensor in rad, and short the connector and see if fans come on. If so, faulty sensor...
fast_pug
  • Warrington
« Reply #5 on: 10 August 2007, 16:23:44 »
Thanks again it was the rad sensor kicks in around 97 now
Cheers for the help
Fast_pug
« Reply #6 on: 10 August 2007, 16:32:04 »
Nice one  :y
I like faults like this.  ;)
