Author Topic: Noisy Cooling Fan  (Read 2487 times)
Boiler Man
  • Sale, Manchester
Noisy Cooling Fan
« on: 06 August 2007, 21:46:09 »
Hi Guys
Wondered if someone can help me.
I have a very noisy radiator fan, it's rattling it's nuts off, it's still working at the mo, but proberbly not for long. :(
Apart from the embaresment when you park up and it's still screeching as you walk away :-[It's on a 2003 2.2 Dti CDX estate and it's the one on the front left of the rad when you lift the bonnet.
Question is, Can you purchase a motor and swap the impellor over from the old one? or do you have to buy the whole lot?
If the later are they pretty universal or will I have to find a second hand one off a later DTI
I should imagine the vx new would be pricey.
Any help would be appreciated :y
« Last Edit: 06 August 2007, 21:50:17 by Boiler_Man »
Omega 2.0 DTI GLS Estate 99 Gold & Omega 2.2 DTI CDX Estate 03 Silver. Just need a Bronze one now for the full set.
Dazzler
  • Haverhill, Suffolk
Re: Noisy Cooling Fan
« Reply #1 on: 06 August 2007, 22:00:28 »
Knowing Vauxhall it will be a whole assy, looks like you need to find one being broken mate. :(
Nickbat
« Reply #2 on: 06 August 2007, 22:12:26 »
I would agree with the above.
Nice to see you back, BM. Where have you been? Oh and by the way, I did replace that rad valve and a fat lot of difference it made!!!  ;D ;D ;D
Boiler Man
  • Sale, Manchester
« Reply #3 on: 06 August 2007, 22:20:42 »
 :y Not been away really, must have just not crossed paths on forum.
I've not been on as much though must admit. I did reply to you PM a while ago about your rad. Time to think of something else before winter. PM me if you fancy retracking on what you did :y anytime
Boiler Man
  • Sale, Manchester
« Reply #4 on: 07 August 2007, 00:08:59 »
Cheers for your comments guys. :y
But can someone tell me.
Are they universal on the facelift or do I need a dedicated DTI version?
megaomega123
« Reply #5 on: 07 August 2007, 02:01:11 »
I had this after a long run and found a tiny stone wedged between the fan and the housing. Worth a look maybe.
Boiler Man
  • Sale, Manchester
« Reply #6 on: 08 August 2007, 11:12:59 »
Cheers mate :y
But I it defo sounds like worn motor bearings or brushes.
« Reply #7 on: 08 August 2007, 11:33:09 »
As per the aircon condenser, they are standard across all models (note some 4 pots only have one front mounted fan)
« Last Edit: 08 August 2007, 11:33:54 by Mark »
Boiler Man
  • Sale, Manchester
« Reply #8 on: 10 August 2007, 16:54:17 »
Cheers Marks DTM Calib  :y
Yes mine only has one fan on the front of the rad and one on the rear. It's the front one thats Squeeling.
So I can pick a second hand one up from any scrap omega? :-/
