Author Topic: Flushing out coolant  (Read 6452 times)
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: Flushing out coolant
« Reply #15 on: 11 August 2007, 12:20:31 »
Hello just about to use the some of this stuff, just been reading the instructions (makes a change) ;) and it says after its been in the system it needs to be flushed through and I need to remove the stat question is do I really need to do this couldnt  I just let it run around and flush it a couple of times it may take longer but will be easier wont it  :)
mahony
  • london
    • omega elite 3.0
« Reply #16 on: 11 August 2007, 13:50:56 »
ive just got some forte radiator flush off of ebay,im not gonna bother with removing the thermostat either,just gonna refill cooling system three or four times with fresh water and then re-fill with a 50/50 water coolant mix.
LFF64
  • HADDENHAM BUCKS
« Reply #17 on: 11 August 2007, 14:46:26 »
Ok just finished doing mine without taking stat out its been flushed through several times and now seems to be more or less just clean water I doubt it would be free from some traces anyway  :) My tempgauge was sitting around 95-97 on all journey types the temp is now reading just over 90 now  :y . The coolant in my system was pretty clean to start with too so just goes to show you cant tell whats inside the engine
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #18 on: 11 August 2007, 18:22:57 »
The Forte Cooling System Flush that I had made no mention of removing the thermostat :-?
« Reply #19 on: 11 August 2007, 19:11:31 »
forte does say remove stat. easy on my tractor.
just flush through a few times, doing a few miles inbetween, then get right 50:50 mix in there.
« Reply #20 on: 11 August 2007, 21:33:11 »
You probably used the one for the oil ::) ;D
The Cambelt Kid
  • Derby
« Reply #21 on: 12 August 2007, 11:19:34 »
Not only does it say remove it, my bottle says replace it?
Why is this?  Is it because the treatment eats at the stat?
I'm reluctant to replace the stat as i works just as it is now.
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #22 on: 12 August 2007, 13:05:42 »
Forte cooling system flush green lid to Quote the instructions
1= SHAKE WELL
2=ADD ONE 500ML BOTTLE TO COOLING SYSEM FLUSH OF A TYPICAL MOTOR VEHICLE
3= IDLE ENGINE FOR 20- 30MINS AFTER REACING OPERATING  TEMP WITH HEATER CONTROLS ON
4=DRAIN THE SYSTEM,REMOVE THE THERMOSTAT AND RINSE THOROUGHLY WITH CLEAN WATER
5=REPLACE THERMOSTAT,REFILL WITH COOLANT AND FORTE COOLING SYSTEM CONDITIONER
Jaguar XJ6
Grumpy
  • Manchester
« Reply #23 on: 12 August 2007, 14:25:56 »
It means put it back in after flushing, not renew it.
It's a bit like the Americans putting warnings on packets of peanuts saying,
"This product may contain nuts".   :D
It's all to do with avoiding litigation, they've told you to take it out for the flush,
so they have to tell you to refit it in case you follow instructions to the letter
and try and sue them.
« Last Edit: 12 August 2007, 14:27:00 by Grumpy »
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #24 on: 12 August 2007, 15:09:27 »
Not on my bottle it doesn't
http://[IMG]http://i155.photobucket.com/albums/s304/Loo-knee/Forte001.jpg[/IMG]
« Last Edit: 12 August 2007, 15:10:07 by Loo-knee »
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #25 on: 12 August 2007, 15:11:39 »
No I didn't ::)
http://[IMG]http://i155.photobucket.com/albums/s304/Loo-knee/Forte003.jpg[/IMG]
