Pages: [1] 2 3  All   Go Down
Author Topic: parts for mv6  (Read 7607 times)
kickboxer
  • lincolnshire
parts for mv6
« on: 06 August 2007, 13:58:44 »
thanks baron.
hi all
iv got an mv6 ex traffic car with a couple of problems
i havent got and headlight adjuster in the car as they are self levelling so i have been told and my motor to do this has gone duz anyone have any ideas where i cud get one and how much they are.
also my abs and trac light is on would anyone take a guess as to which sensor and how many have gone or wud u think that a stage 2 diagnostic would be the best way to go............
i know the cars are punishing on fuel but cud anyone tell me can the cars be superchipped.............
Markjay
  • London
Re: parts for mv6
« Reply #1 on: 06 August 2007, 15:37:06 »
If the car is 3.0 (i.e. not 3.2) then talk to M-Tek performance about chipping , he is a member on this site. As far as I know there are no chips for the newer engines i.e. 2.6 & 3.2, maybe because it requires re-flashing the ECU instead of replacing a chip.
Not sure about your other problems, but if you are anywhere near TheBoy then he has the original Tech2 diagnostic tool - and unlike Vx dealers he actually knows how to use it, and use it well he does. But be quick because his Tech2 is about to go...  :(
Alas, no more Omegas....
kickboxer
  • lincolnshire
Re: parts for mv6
« Reply #2 on: 06 August 2007, 15:44:17 »
mine is the 3ltr mv6
i dont know how to use this site properly and its my first time trying to use it to get information on it so could you point me in the right direction to whom you was on about please many thanks
Re: parts for mv6
« Reply #3 on: 06 August 2007, 16:23:38 »
:)Hi Kickboxer and welcome to the forum. Without meaning to sound rude, if you wait a while some of the more knowledgable chaps here will offer advice re; your problems then at leats you will be heading in the right direction.  :y
kickboxer
  • lincolnshire
Re: parts for mv6
« Reply #5 on: 06 August 2007, 16:28:49 »
i understand i'm just eager to try and get it sorted so i don't have to worry as the mot is due soon
Dazzler
  • Haverhill, Suffolk
Re: parts for mv6
« Reply #6 on: 06 August 2007, 17:12:25 »
ABS/TC light on, if the speedo has stopped as well then it more than likely to be the ABS ECU. You can try and clean the n/s rear ABS sensor first to see if it helps. The only true way to be certain is via Tech 2 to see if it can talk to the ECU or not. IIRC.
kickboxer
  • lincolnshire
Re: parts for mv6
« Reply #7 on: 06 August 2007, 18:07:44 »
speedo not working either but thats something i will get my mate to look at as he knows more about cars than i do many thanks
Re: parts for mv6
« Reply #8 on: 06 August 2007, 19:56:54 »
But as Dazzler says your lack of ABS TC & speedo is all the same (likely to be expensive :'() problem. ;)
Re: parts for mv6
« Reply #9 on: 06 August 2007, 22:15:46 »
If its a post 98 car, I reckon your ABS ecu is busted.
HIDs, expalin your problem again, its not clear...
kickboxer
  • lincolnshire
Re: parts for mv6
« Reply #10 on: 06 August 2007, 22:25:19 »
abs/tc light on all the time and a mate has cleaned the rear sensors but the lights are still on and the speedo isn't working i have a price for the sensors but someone else has said that it may be the abs ecu thats gone if so where would i get another and would a brand new one from a dealer going to make me wana sell the cats lungs or the car hehehe also i'm after a black load cover if anyone has one for sale
its a 2000 model on an x
ex traffic car
Re: parts for mv6
« Reply #11 on: 06 August 2007, 22:31:01 »
ex traffic car
get a refurb ecu.
so, whats wrong with Hids?
kickboxer
  • lincolnshire
Re: parts for mv6
« Reply #12 on: 06 August 2007, 22:32:52 »
where would i get a refurb ecu and do they have to be coded to the car
and whats hids
Re: parts for mv6
« Reply #13 on: 06 August 2007, 22:44:54 »
and whats hids
yes, needs to be configured for car. others have done, so should be able to recommend supplier.
HIDs - Xenons, you said you had a problem?
kickboxer
  • lincolnshire
Re: parts for mv6
« Reply #14 on: 06 August 2007, 23:07:15 »
yes sorry,i havent got an inside adjuster switch aparently my headlights are self leveling ones and the motor has aparently gone because a light is on underneath the digital part of the dash i.e where the time and that are.
we have managed to adjust them manualy tonight but they aint high enough and that took soom doing im begining to regret getting this car and the mot is due in 10 days
Pages: [1] 2 3  All   Go Up
Page created in 0.03 seconds with 20 queries.
