Pages: 1 2 [3]  All   Go Down
Author Topic: parts for mv6  (Read 7604 times)
kickboxer
  • lincolnshire
Re: parts for mv6
« Reply #30 on: 11 August 2007, 21:53:05 »
how long will it take to code then?
is it only the t/c that needs coding
Re: parts for mv6
« Reply #31 on: 11 August 2007, 22:59:28 »
ABS/TC unit just needs telling correct config, about 10 - 15m
MartinP
  • Dudley
    • BMW 320D
Re: parts for mv6
« Reply #32 on: 12 August 2007, 19:37:03 »
I had the same problem and swapped out the ECU from a same year 2.5, the speedo, ABS and TC worked straight off.
You may be lucky  ;)
I still need it re-coded as it is slightly off.
When the money is in hand, I'll be visiting The Boy.
Re: parts for mv6
« Reply #33 on: 12 August 2007, 20:14:01 »
You may be lucky  ;)
Marks_DTM also currently has the facilities if thats closer for you.... ;)
kickboxer
  • lincolnshire
Re: parts for mv6
« Reply #34 on: 12 August 2007, 20:30:49 »
now that hopefully i have the problem sorted out can any1 tell me the best place to get an irmicher front grill from?????
and how much they might cost
MartinP
  • Dudley
    • BMW 320D
Re: parts for mv6
« Reply #35 on: 12 August 2007, 20:43:04 »
You may be lucky  ;)
It runs and gets me to work and back.
it's more important to change the leaking cam cover and the dis pack  :(
Pages: 1 2 [3]  All   Go Up
