Author Topic: Relays  (Read 1608 times)
Lion
  • Lincoln
Relays
« on: 12 August 2007, 17:41:19 »
Hello - does anyone know where i can find the relay for the heater/aircon blower in my omega? Ive had a look under the bonnet & there just numbered - do the numbers correspond to the numbers of the fuses? Its not in the fusebox either - ive had a look at those.
Cheers
P.s its the pre facelfit 3.0v6 Elite if that helps
Re: Relays
« Reply #1 on: 12 August 2007, 17:44:51 »
Cheers
See the FAQ section for relevent relaybox layouts....  ....though I dont think there are any relays for it?
What is problem?
Re: Relays
« Reply #2 on: 12 August 2007, 17:47:53 »
Look hereX25XE and X30XE Engine Bay Relay Box layout
Re: Relays
« Reply #3 on: 12 August 2007, 17:49:07 »
Sorry about last post. Look in Technical Info. Should be number 7 relay.
Lion
  • Lincoln
Re: Relays
« Reply #4 on: 12 August 2007, 17:59:08 »
Thanks for the help - unfortunately the k7 realy what it lists in the haynes isnt on there  :'(
The problem is the fan won't switch off - even with the engine off & key out - atm im having to keep pulling the fuse & putting it back in whenever i want aircon
Re: Relays
« Reply #5 on: 12 August 2007, 18:08:09 »
Ah, since the heavy rain no doubt?
Blocked scuttle drain, causing water to come up through pollen filter into passenger footwell, dripping on fan speed controller in process....   ....and they ain't cheap.
Edit: I presume you mean cabin fans, not cooling fans?
« Last Edit: 12 August 2007, 18:09:20 by TheBoy »
Lion
  • Lincoln
Re: Relays
« Reply #6 on: 12 August 2007, 20:41:53 »
I bought the car like it - so im not sure if it was after the rain / not.
I can select all speeds fine however - its really bugging me now lol, the garage is kind enough to give me a complete new unit & parts - but i dont want to take the dash out if its not that (as they dont know either) ::)
And i mean the fans that blow hot/cold air into the car - not the rad fans.
If i cant sort it soon - i may modify a switch from a scrapper and wire it in as an on/off switch as stripping the dash is a real bore lol
Cheers
Re: Relays
« Reply #7 on: 12 August 2007, 21:00:48 »
The speed controller is up behind glovebox, a seperate unit to main climate panel (which is a 30min job anyway) bolted to fan housing
Lion
  • Lincoln
Re: Relays
« Reply #8 on: 12 August 2007, 22:33:44 »
Cool cheers - i will replace this and see if it solves it  :y
Re: Relays
« Reply #9 on: 12 August 2007, 22:35:05 »
Its an expensive part, so may be worth measuring the volatages, unless you happen to have a spare?
