Author Topic: Another broken pipe  (Read 2102 times)
AndersH
  • Poole
Another broken pipe
« on: 16 August 2007, 13:32:26 »
I was just about to start the task of cleaning my breathers and to fix the split pipe I had when I saw this:
Not totally sure how easy it is to work out from the picture, but the larger pipe coming from the ICV has a smaller one branching out from it and it is at completely the wrong angle and has been doubled back on itself and has broken and is only just hanging on  :o
Looks like I'll have to replace the whole lot, what problems could this have been causing? also does anyone have a  part number and an approximate price please?
Thanks!
Matchless
  • Nottingham
    • A white van
Re: Another broken pipe
« Reply #1 on: 16 August 2007, 13:40:53 »
Would cause an air leak after the air-mass meter.
New hose likely to be expensive...tried a breakers?
Pete Elite
  • Uxbridge, Middlesex
« Reply #2 on: 16 August 2007, 14:19:14 »
 I have sort of the same problem, where the smaller pipe joins the bigger pipe the joint is not sealed all the way round.
 Would it be ok to use a silicone sealent to fill the slight gap, like say a windsceen or bath sealent, so should be air tight and flexible :question.
     Thanks,
               Pete :y.
AndersH
  • Poole
« Reply #3 on: 16 August 2007, 14:33:18 »
Well I've just been to the breakers - a 5 min walk away and they only had one Omega and 2 of us tried for 15 mins to get the bonnet open but failed! Not sure what to do now, has anyone got one from a car that they're breaking?!
Cheers!
Pete Elite
« Reply #4 on: 17 August 2007, 00:29:33 »
http://cgi.ebay.co.uk/OMEGA-2-5-3-0-V6-IDLE-CONTROL-VALVE-ICV-WITH-PIPE-MINT_W0QQitemZ200141108999QQihZ010QQcategoryZ10404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
   Hi,
      This is what your looking for  :)but will have to buy ICValve as well :(.
            Pete :y.
AndersH
  • Poole
« Reply #5 on: 17 August 2007, 00:32:41 »
Ah thanks for that! suppose it can't hurt to have another ICV?!
Pete Elite
« Reply #6 on: 17 August 2007, 00:36:57 »
 No Probs,
              Was thinking of buying it myself but my pipe should be easy to fix as only come adrift slightly where it joins the bigger pipe :).
        Pete :y.
