Author Topic: ran  out of petrol now wont start (2.5 v6 cdx)  (Read 4084 times)
stumpy451
  • chesterfield, derbyshire
« on: 13 August 2007, 16:38:09 »
have had my car for about 4 months and had no problems. it ran out of petrol on sunday and i put 15 litres in and some red ex. now there is a warning light on. it is a picture of an engine with a spark through it. it keeps stalling even when driving. its an automatic. when it stalls i still have power steering untill it rolls to a stop then nothing. when i try to restart it, it just turns over but eventualy just picks up but then within a few hundered metres stalls again. any help would be apreciated thanks.
« Last Edit: 13 August 2007, 16:44:15 by stumpy451 »
a2reed
  • Battersea London
Re: ran  out of petrol now wont start (2.5 v6 cdx)
« Reply #1 on: 13 August 2007, 16:51:49 »
Sounds like a crankshaft sensor failure or possibly an immobilizer fail
x25xe
  • Hayes, Middlesex
  • Avater removed due to size
« Reply #2 on: 13 August 2007, 17:07:15 »
Due to the running out of fuel, I would also get a new fuel filter and fit it.  Running problem could be a lack of fuel supply caused by a blocked filter.  This would cause a lack of fuel pressure which may trigger the EML.  Could also be a fouled plug causing poor sparking which may also trigger the EML.  This is just a theory.
Symptoms are like a crank sensor, but I have read in the past that when they die no amount of cranking will get it started again until the engine has cooled down.  Have you have starting issues in the past?  By this I mean has the engine taken a long time to start?
RolandL
  • Doncaster
    • M/facelift 2.5 V6 Elite
« Reply #3 on: 13 August 2007, 17:09:42 »
sounds like crank sensor if you have a V6 there's a how to
here....http://www.omegaowners.com/forum/YaBB.pl?num=1174321688
The faster you go the bigger the grin.  Trade card user.
« Reply #4 on: 13 August 2007, 17:12:19 »
Due to fuel prob, replace the fuel filter anyway...
stumpy451
« Reply #5 on: 13 August 2007, 18:00:40 »
hi thanks for all your posts does anyone know of where i can get a fuel filter and how much?
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #6 on: 13 August 2007, 18:02:54 »
vaux ones are about £15, its the plastic ends that aree a pain in the a$$ to deal with
nixoro
  • Hitchin, Herts
« Reply #7 on: 13 August 2007, 18:05:54 »
Have you tried to paperclip test it to see what codes can be seen if only to confirm the crank sensor that has already been mentioned.
IrmscherKris
  • Manchester
  • banned due to bad trader references
« Reply #8 on: 13 August 2007, 18:08:52 »
how much redex did you add to the £15?
stumpy451
« Reply #9 on: 13 August 2007, 19:02:00 »
the bottle treats 1 full tank so i put about about a 1/4 to 1/2 bottle in
stumpy451
« Reply #10 on: 13 August 2007, 21:46:22 »
if i press the accelerator to the floor then start it it will start and rev high but when the revs come back down it just dies again.
« Reply #11 on: 13 August 2007, 22:44:33 »
the situation you tell give me the idea of fuel air mixture problem.Either too much air or less amount of fuel can cause this.Whats the mileage of car? What are the codes from the ECU ?
PS: Together crank sensor problem I dont think you can rev high
« Last Edit: 13 August 2007, 22:47:24 by cem_devecioglu »
Matchless
  • Nottingham
    • A white van
« Reply #12 on: 13 August 2007, 23:05:08 »
I wonder if the Idle Control valve is sticking? its an auto so when you ran out of fuel it could well have wound fully open to try to keep the rpm up.
Its easy to check, remove it and flush the valve with WD40 or carb cleaner then add a little light oil and refit.
stumpy451
« Reply #13 on: 16 August 2007, 09:23:31 »
thanks for all your answers
just an update I have had the fuel filter changed and it still wouldn’t run so I got a mobile mechanic to run a diagnostics and it said that the mass air flow meter problem. I asked Autosuplies and they quoted me £220! so I got one from a local vehicle dismantlers and he assured me that it was from my car but the plug is different. so I need to find one. any ideas people?
cheers
« Reply #14 on: 16 August 2007, 10:42:20 »
The general concensus on here is that MAFs very rarely go wrong and that this fault code can be caused by many other problems, specifically air leaks, leaky EGR valves and the like. I certainly wouldn't fork out that sort of money without more investigation. Apparently MAFs can be cleaned with computer foam cleaner too.
Page created in 0.03 seconds with 20 queries.
