Author Topic: Manual Gearbox issues  (Read 4021 times)
Matchless
  • Nottingham
    • A white van
Re: Manual Gearbox issues
« Reply #15 on: 17 August 2007, 16:19:44 »
Fully stamped service book but the hydraulic fluid is dark brown?  :o :o
Its supposed to be changed every 2 years!!!
A clutch bleed wont hurt and is easy to do. But follow the maintainance guide and bleed and service your brakes at the same time.
Sort out the clutch once the important safety bits are right.
JasonH
« Reply #16 on: 17 August 2007, 21:14:00 »
You will have to bleed the clutch after changing it because you have to disconnect the hydraulics to get the gearbox off.
