Author Topic: It's all gone belly up!  (Read 3747 times)
IrmscherKris
  • Manchester
  • banned due to bad trader references
« on: 17 August 2007, 11:16:37 »
Right, I bought an MV6 with HGF, fixed that put everything back together - didnt start after muchas rather about I learned the fuel pump wasnt priming.
I cpoke to the guy I bought it off who said he too had that problem but after a sparky looked at it they bought a new crank sensor and they had to reprogram the chip in key.
He went on to say that there is a 30 amp fuse in the engine bay (in the triangular bo at the smallest part which was blown and they changed after the new sensor was fitted).
I drove the car before doing the HG and it did have a missfire (I assume due to water in the bore).
still reading?  ;)
I had a play with the fuel pump relay and now it works.....? (opened and manually pushed arm across)
The thing is now, when I try to start it, it pops and farts but wants to run until I open the throttle - then it sounds like theres nothing there?
EML goes out while cranking.
Inlet stripped down and rebuilt (twice to be sure everything is plugged in)
NEW: dispack, plugs, leads, crank sensor and timing belt kit (timed up using locking kit)
I'm absolutely stumped on what to look at next.
Any ideas appreciated  :y
Re: It's all gone belly up!
« Reply #1 on: 17 August 2007, 14:09:27 »
Think may be still there's timing problem..
IrmscherKris
  • Manchester
« Reply #2 on: 17 August 2007, 14:15:41 »
Thanks, I'll check the timing again though I must of checked 5 times when I timed it up the first time round.
It seems to have a weak spark...
« Reply #3 on: 17 August 2007, 14:28:25 »
When cranking, above a certain amount of throttle disables fuelling (flood clear mode) so maybe this is why it tries to fire until you give it throttle.
It might be worth putting a timing light on one of the plugs and making sure you're getting a strong, regular spark. If that's OK double check you've got the plug leads to the right cylinders.
Have you got a smell of fuel on the plugs?
If you press the little schrader fuel pressure test point at the rear of the fuel rail do you get a good squirt of fuel? (Cover it with a rag so you don't get doused)
It might be worth getting a can of Bradex easy start. Spray a load of this into the Multiram then crank. If it fires on this it points to a lack of fuel.
Get some Noid lights and make sure the injectors are getting a pulsed signal when cranking.
If the 30A fuse has blown before it does point to something going wrong in the engine management system. I'd have a careful look over the engine loom and in the cable trays for any sign of damaged or melted wiring. Maybe something has shorted out in there.
IrmscherKris
  • Manchester
« Reply #4 on: 17 August 2007, 20:11:30 »
What a muppet! re-checked the timing...... cam no 3 was 180 deg out......
I'll get my coat  :-[
« Reply #5 on: 17 August 2007, 20:35:09 »
Gack!!!!
Has there been any damage?
Please, pleeeease.... time it up with a timing kit...
Timbuk
  • Telford
  • owned a Datsun 120y once!
« Reply #6 on: 17 August 2007, 20:41:33 »
Lordy Lord  :o
IrmscherKris
  • Manchester
« Reply #7 on: 17 August 2007, 20:56:30 »
I did use a timing kit..... then I sent it back (autovaux) as it was timed up.
The mistake I made was when I put the cam pully on I put it on as a 4 - instead of 3.
Really stupid I know but I did have 3 kids running riot a yapping staffy and a nagging missus all at once.
Managed to not upset the timing when flipping the cam round - RESULT!
Thanks for everyones help  :y
« Reply #8 on: 17 August 2007, 20:56:31 »
tut tut.
Still, I think that won't cause damage, so just fix it...
« Reply #9 on: 17 August 2007, 21:05:56 »
If it was 180 out it should be OK. It would explain why it didn't run desperately well, though :-[
Dazzler
  • Haverhill, Suffolk
« Reply #10 on: 17 August 2007, 21:25:54 »
Much better to be 180 out rather than a few teeth ;)
davlad22
  • Sunny Yorkshire
« Reply #11 on: 17 August 2007, 21:49:07 »
Does it go like a rocket now then!?!
IrmscherKris
  • Manchester
« Reply #12 on: 17 August 2007, 22:01:23 »
Not yet, I'm having a prob bolting the L/H downpipe back to the manifold so sounds like a tank and havent been able to open it up yet.
Busy day tomorrow too then - various bulbs in dash etc  :y
« Reply #13 on: 17 August 2007, 22:10:27 »
But it does run now?
« Reply #14 on: 17 August 2007, 22:12:34 »
happy to hear (read) you find the problem  :y
