Author Topic: Rams dont work  (Read 1240 times)
omegabeast
Rams dont work
« on: 19 August 2007, 10:43:34 »
Hi,
Loo Knee just been down mine to help me with my oil leak (on another post). But we have found that both dual rams dont work.
Any ideas why this would be?
The one at the back of the engine doesnt open with a blip or the one at the front doesnt work at 4k rpm either.
The breathers dont seem to be blocked either
Matt  :y
Re: Rams dont work
« Reply #1 on: 19 August 2007, 10:52:51 »
You need to start by checking all the vac pipes.....does your car have the front mounted vac tank (on the bottom of the inlet trumpets)?. If so, then make sure that the vac connctions are the right way round with the feed on the right and the output on the left.
omegabeast
Re: Rams dont work
« Reply #2 on: 19 August 2007, 10:57:38 »
Hi,
Thanks for the reply.  The vac tank is mounted on the front i think yeah. Im not that clued up on engines yet so ill have a look to see if the connections are right.
Might need some help though as dont really know what im looking for
Matt :y
omegabeast
Re: Rams dont work
« Reply #3 on: 19 August 2007, 13:13:10 »
I dont know if this has anything to do with it but ive just been out in the car and when i floor it i hear a really big sucking sound. My old one didnt do that?
Matt
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Rams dont work
« Reply #4 on: 19 August 2007, 14:01:24 »
Yes Mark it has the Vac Tank on the bottom left of the engine bay, both connections sort of wobble when you touch them at the Vac Tank but seem to be attached..
Told Matt about the diagram you have put in the Maintance Section to follow to make sure the pipes are going to the correct place.
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Rams dont work
« Reply #5 on: 19 August 2007, 14:18:07 »
Ok I have printed out the route of the Multi Ram Pipes and will go back down Matt's to see if its right...
But say it is all right could the Vac Tank not be working? If so, if i connect the two pipes to bypass the Vac Tank should Both Multi Rams start to work?
There is a test to do to check that the Vac Tank is working, Elite Pete was telling me earlier but have the attention span of a goldfish ;D
