Author Topic: Help needed with fuel filler flap  (Read 2521 times)
RolandL
  • Doncaster
    • M/facelift 2.5 V6 Elite
« on: 20 August 2007, 18:09:45 »
Hello peeps, have a problem with locking mechanism on the fuel filler flap. SWMBO went to fill up and couldn't open it. Solenoid is shot, it needs replacing. How do you remove the solenoid ( Black box) have tried but can't work out how it comes out, anybody know the secret ????
The faster you go the bigger the grin.  Trade card user.
Grumpy
  • Manchester
Re: Help needed with fuel filler flap
« Reply #1 on: 20 August 2007, 18:29:09 »
Not removed one of these, but had a quick look in the Haynes manual
for you.
Open the side trim panel in the boot.
Remove the wiring plug, and there are 2 easily accessible bolts
to remove which allows the the solenoid to be removed complete
with its mounting bracket.
RolandL
  • Doncaster
« Reply #2 on: 20 August 2007, 18:34:29 »
for you.
Remove the wiring plug, and there are 2 easily accessible    ;D    bolts
Had a look and couldn't see any bolts, will have another look.
Thanks for the prompt reply   :y
Roland
Grumpy
  • Manchester
« Reply #3 on: 20 August 2007, 18:42:42 »
Just had a quick look at mine and you can't miss them.
Fold down the rear right hand panel after undoing the 2
quick release fasteners.
The 2 crosshead bolts are horizontal, mounted on the flange
directly in front of the servo motor.
RolandL
  • Doncaster
« Reply #4 on: 20 August 2007, 18:56:18 »
 :-[  how stupid do I feel.  I can change an air con condenser, but can I see two obvious bolts, Doh!
 thanks
Grumpy
  • Manchester
« Reply #5 on: 20 August 2007, 19:03:01 »
You're not at all stupid!!
Stupid folk are those that don't ask questions.  ;)
Remember that the only stupid question is the one that
you don't ask.  :)
Martin_1962
« Reply #6 on: 20 August 2007, 19:37:21 »
Just the two screws - 10 minute job (sorry Issunaz)
MartinP
  • Dudley
    • BMW 320D
« Reply #7 on: 20 August 2007, 20:18:24 »
Martin_1962
« Reply #8 on: 20 August 2007, 20:48:47 »
It was in my garage for nearly a year :-[
