Author Topic: rattling sound coming from manifold  (Read 2132 times)
madmax
  • costa del essex
« on: 19 August 2007, 20:21:52 »
hi all started my car this morning and was greeted with a loud hollow sounding rattle seemed to be coming from underneath manifold at the front died down when idle dropped down after warming up but still noticable..i know its not much to go on but anyone got any ideas....1998 mv6
ians
  • Reading
Re: rattling sound coming from manifold
« Reply #1 on: 19 August 2007, 20:31:50 »
failing manifold gasket? (hopefully not cracked manifold).   Noise often reduces as it warms up so symptoms seem to fit.
Others more familiar will confirm or otherwise..
hotel21
  • The Kingdom of Fife
« Reply #2 on: 19 August 2007, 20:53:35 »
Have you checked the heat shields for security?  A jubilee clip or two can sort it if the securing bolts are rusted through, causing them to vibrate a bit when at idle or critical revs as the engine revs drop down.
madmax
  • costa del essex
« Reply #3 on: 19 August 2007, 21:04:50 »
i,ll check these out in the morning its peee..ing down outside at mo, thanx for the advice ill let you know what i find tomorrow!!!!!!!!
omegabeast
« Reply #4 on: 19 August 2007, 21:09:03 »
My old one used to do this.  It was the manifold gasket. Used to go when the car was warmed up and the metal had expanded with the heat!
Matt  [smiley=beer.gif]
madmax
  • costa del essex
« Reply #5 on: 21 August 2007, 15:20:22 »
further investigation and it seems to be fan belt tensioner i havent took the belt of just moved tensioner forward with spanner and noise went...glad it werent cambelt side!!!
