Author Topic: ProSan Diagnostic software  (Read 2244 times)
old cruiser
  • Slough
« on: 20 August 2007, 09:04:48 »
Anyone had any joy using ProScan software with ELM327 interface?, I can't get it to  talk to the Ecu at all with mine.
Cheers Pete
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
Re: ProSan Diagnostic software
« Reply #1 on: 20 August 2007, 12:44:17 »
What about getting a program called "portmon" think its free from microsoft might be able to see what happening on the serial port?
Hav'nt tried that software.
Does your year have the canbus?
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
old cruiser
  • Slough
« Reply #2 on: 20 August 2007, 13:38:21 »
Cheers Mate, I'll have a look at that; not sure if mine is Can-bus or not.
Cheers Pete
« Reply #3 on: 20 August 2007, 13:50:25 »
Yours is not CAN.
scantool (scantool.net) is free and works with elm chips.
old cruiser
  • Slough
« Reply #4 on: 20 August 2007, 14:34:34 »
The boy, I've got the scantool software and works a treat , but looking around for something a little more comprehnsive.
Cheers Pete
« Reply #5 on: 20 August 2007, 14:37:19 »
Cheers Pete
You're knackered if you want to read much more than engine for a variety of reasons - OBDII generic readers will usually only cover engines, and Omega's diagnostics port uses 4 diag lines, rather than the usual one.
Cheapo Tech2 (buggy, and often Hungarian) or real Tech2 (expensive) are your best bets...
« Last Edit: 20 August 2007, 14:38:13 by TheBoy »
iggy21uk
« Reply #6 on: 20 August 2007, 16:20:46 »
Opel Autoscanner - shows 2003 2.2 gearbox in the menu.
Hav'nt tried connecting though.
Works on my 99 2.5
« Last Edit: 20 August 2007, 16:21:09 by iggy21uk »
« Reply #7 on: 20 August 2007, 21:55:08 »
Works on my 99 2.5
I need a play with one of these....
« Reply #8 on: 20 August 2007, 22:22:14 »
That scan piccie looks odd ... mine is definately a Dec 1999 V plate ... that shows V plates as 97 !!! something wrong methinks ...  :(
« Reply #9 on: 20 August 2007, 22:39:28 »
Thats the VIN year and completely unrelated to reg...
« Reply #10 on: 21 August 2007, 22:12:38 »
Thanks for that info .. still learning lots !!
(bit off topic now .. apologies !! )  :-/
So, picking your brain further ... which part of the VIN is the "year" bit ?? My "first registered Dec99 V Plate" has both a W (first digit), V (5th digit) and an X (10th digit) in the VIN - be interested to know when it was "made" rather than "registered"
Regards
« Last Edit: 21 August 2007, 22:13:27 by entwood »
« Reply #11 on: 22 August 2007, 21:18:54 »
Regards
Last letter in the VIN on 2000 and earlier, W being 1998, X 1999, Y 2000... (U us skipped)
