Author Topic: Exhaust Manifolds are the 2.0 & 2.2 the same  (Read 1430 times)
bash
  • Doncaster
« on: 23 August 2007, 21:35:15 »
  [size=14]   I have just found my exhaust manifold cracked. OK i admit i did not believe members who told me to double check. My car is the later 2.2 litre engined car, is the manifold the same as the early 2.0 litre cars the engines look the same 4 cylinder Eco engines. Because there are very few 2.2 cars being broken but lots of 2,0 litre ones
                        Also there are two studs snapped, has any one had any luck drilling them out in situ, plus do you think the cracked exhaust manifold could be my rough idle problem cheers bash[/size]
« Last Edit: 23 August 2007, 21:37:21 by bash »
Re: Exhaust Manifolds are the 2.0 & 2.2 the same
« Reply #1 on: 24 August 2007, 00:38:44 »
Hi Bash :)
The early 2.016v cars have secondary air injection, which the 2.2 does not have. So in short, they're not really interchangable. you COULD fit the 2.0 manifold, and somehow bung up the SAI pipe, but this would be very unprofessional bodge, and not at all recommended.
As far as the idle probs are concerned - an exhaust leak pre-lambda won't help matters, however also make sure that your idle control valve is cleaned out, throttle body is cleaned out, and the crankcase breather system cleaned out. If you need any help with this, do post up. Also - check for fault codes - (search for paperclip test on here).
« Reply #2 on: 24 August 2007, 09:23:29 »
different part numbers, so I guess not...
holey head
  • leeds uk
  • i'm a new dad
« Reply #3 on: 24 August 2007, 15:20:38 »
the drill in situ part, i had to get an engineer out to do mine!
ouch my head hurts! i'll try and remember to wear my helmet next time i'm out on the quad!
omegadan2.2i
  • Worksop, Notts
« Reply #4 on: 24 August 2007, 21:46:52 »
You need to sort your manifold problem first before your idle problem as a cracked manifold and nuts/studs not sealing against the cylinder head will certainly not help your problem with the idling.
There are some 2.2's being broken out there but you would probably need a more 'specialist' late Vauxhall breaker to have more chance of finding what you need.  I don't know what is near Doncaster area but in Notts/Derbys there is http://www.megavaux.co.uk near Nottingham (just off J25 M1) they have a good website which lists all the Omega's they have in including several 2.2's.  I have not tried them myself yet but I am going to try them for a cat for mine.  The only problem with a used one is finding a good one as this is a common fault unfortunately.  A new one from Vx is approx £100+ VAT on TC I think.
The snapping of the studs is also common which I experienced myself and yes it has to be the one near no.1 cylinder right at the front which is a real bs'tard to do.  Fortunately, there was enough thread in the head to re-use so hopefully this will hold.  Several members with 2.2's (and 2.0's) have also found 'bodged in' studs where previous 'messers' have made a bodge job of it, so you are not on your own!
Get this sorted first and then see what idle problems you have afterwards and if you still have no joy, as I said before try Marks_DTM Calib as he maybe able to help!
Good luck! :y
Dan
Page created in 0.022 seconds with 20 queries.
