Author Topic: Transmission line pressure adjuster?  (Read 1692 times)
alanfp
  • Chelmsford, Essex
« on: 25 August 2007, 13:00:50 »
I have a "Rosmore GM transmission line pressure adjuster" fitted to my car with Scotchlocks.  It's a small aluminium box (8cmx8cmx4cm) screwed onto the bulkhead. I know that's what it is because that's what it says on the label!
Any idea what it does (and why it might have been added). I can't believe it's a genuine VX fitment.
Alan
Markjay
  • London
Re: Transmission line pressure adjuster?
« Reply #1 on: 25 August 2007, 23:50:45 »
This is what a bit of goggling unearthed:
http://www.otsparts.com/products.htm
OTS & Rosmore Ltd
TCC Adjuster
Negative Switched
Part # TCC-ADJ
The TCC Adjuster functions by altering the computer strategy that controls the TCC which yields the folowing advantages:
1. Cures shudder problems caused by slow application.
2. Reduces Clutch Slip
3. Reduces heat in the Converter Clutch.
Another advantage of the TCC Adjuster is it helps to ensure that the TCC is not brought in too early while under heavy acceleration.
The Unit is:
1. Quick and easy to install.
2. Low cost.
3. Designed to fit negative switched transmissions.
4. Easy to adjust.
5. Small size 51mm x73mm x25mm (d x w x h).
Alas, no more Omegas....
DaveL
  • Nr. Cupar, Kingdom of Fife
« Reply #2 on: 26 August 2007, 07:57:32 »
OTS & Rosmore Ltd
TCC Adjuster
Negative Switched
Part # TCC-ADJ
The Unit is:
2. Low cost.
4. Easy to adjust.
Or of course the transmission could be maintained with good servicing!! But if this device works for you then fair enough. ;)
« Reply #3 on: 26 August 2007, 10:56:04 »
Or decent firmware on the ECU ;)
