Author Topic: Headlight problem  (Read 2531 times)
omegabob
  • Solihull,West Midlands
  • Omega,s Rule
Headlight problem
« on: 26 August 2007, 23:12:34 »
Hi Folks,I know I have asked this question before about water on the inside of the drivers side headlight and I had some answers telling me to take the bulb out and use a hairdryer,but in the manual it tells you not to remove the bulb(garage only)because of high voltage.when I look at the headlight,you have the indicator bulb then what looks like a small spotlight bulb.is this the one I remove and how do I take it out?can anybody help me out on this one please.  Regards to All
Re: Headlight problem
« Reply #1 on: 26 August 2007, 23:20:27 »
High voltage only relates to the xenon headlamp. Yours being the GLS will only have standard projectors. No worries over voltage issues. :y
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #2 on: 27 August 2007, 16:22:08 »
You car could have xenon lamps so be carefull. the xenon lamps have a large ballast pack on the bottom of the light unit.if it has then dont remove the bulbs. uprated xenon and halogen lights were fitted after model year 98/99 due to complaints about poor light output on std lights. ::)
Jaguar XJ6
Markjay
  • London
« Reply #3 on: 27 August 2007, 16:23:44 »
I think the giveaway is that Xenon HID lights came with headlamp washers as standard...
Alas, no more Omegas....
omegabob
  • Omega,s Rule
« Reply #4 on: 29 August 2007, 21:45:02 »
Thanks for the info,but i am still not sure how to take the bulb out assuming it is the one that looks like a small spotlight bulb,is there anybody that can educate me on the procedure.
Best Regards All
omegabob
ians
  • Reading
« Reply #5 on: 29 August 2007, 23:50:57 »
Assuming its not xenon..
remove triangular panel on top,  pull off black rubber cover off the back of the headlamp unit, disconnect wires,  then I recall there is a clip you have to squeeze and that then hinges back. bulb then comes out freely.
I'm surprised if this isn't covered in the manual/Haynes though..
Ghosts in my machine
  • Derby
« Reply #6 on: 30 August 2007, 08:14:38 »
I tried the hairdryer technique. It worked, but only temporarily. I suppose success is based on the reason why there is water in there in the first place.
After the condensation started to come back, dried out headlight again then I taped a sachet of Silica Gel (the sort you get in packaging for electronic items/bags etc) into one of the rubber bulb covers. Has worked for 6 months now.
Dyslexic dwarves.... there not big and they're not clever!
omegabob
  • Omega,s Rule
« Reply #7 on: 30 August 2007, 18:46:15 »
Thanks folks for that,I will give it a go,I did think of when I eventually dry it out running a bead of silicon round the headlight unit where the clear lense meets the back of the unit,anybody tried this.?
Regards All
« Reply #8 on: 30 August 2007, 20:33:28 »
Regards All
that sould be sealed anyway....
