Author Topic: Please Advise  (Read 2985 times)
Crazydad
  • Germany
    • 2.5 V6 facelift
Please Advise
« on: 01 September 2007, 14:47:36 »
I will have to tell you the Story..................Draw up a chair...
Bought the car 4 months ago all was well.......... new belt, tensioners oil cooler head gasket water pump plugs oil filter (just been serviced)
then after about 3 weeks it started cutting out at 5200rpm i thought that i just needed to blow it out a little as the previous owner was an elderly woman who cr@ped herself doing more than 50 in it.
From then it started getting worse lack of power above 3500rpm very slow acceleration in 5th gear
i could feel it wasn`t happy
It feels as if its running out of Petrol, cutting out all the time when i`m running, tick over is perfect and as it is`nt always so i`m thinking fuel filter as i think this has not been done bought one from fleabay original Vx with clips for 11 pound including P&P
Just fitted the new Fuel Filter trouble still there............................ >:( >:( >:(
Just done the paperclip test showed me code:
16..........Knock sensor 1
19..........RPM Signal (Crankshaft sensor) Please read last thread to get InsightI nformation:
http://www.omegaowners.com/forum/YaBB.pl?num=1188640682
« Last Edit: 01 September 2007, 21:44:26 by Crazydad »
davlad22
  • Sunny Yorkshire
Re: Please Advise
« Reply #1 on: 01 September 2007, 14:54:44 »
Does it start again when it stalls? Crank sensor changed yet?
Crazydad
  • Germany
    • 2.5 V6 facelift
Re: Please Advise
« Reply #2 on: 01 September 2007, 15:01:57 »
Thats the thing it does`nt stall...........the revs cut out at abot 3000 (although not always) i take my foot off the accelerator and all is back to normal...........wel not normal i can feel that the engine wants to go but seems restricted.
Crank sensor as far as i know has not been changed.
STMO123
Re: Please Advise
« Reply #3 on: 01 September 2007, 18:46:53 »
When my knock sensor went I lost quite a bit of power. It looks like you've got two sensors to change there.
JasonH
Re: Please Advise
« Reply #4 on: 01 September 2007, 18:58:52 »
Knock sensors don't often fail. It's usually the wiring, it gets trapped or damaged.
The knock sensor fault will really hold the engine back.
Crazydad
  • Germany
    • 2.5 V6 facelift
Re: Please Advise
« Reply #5 on: 01 September 2007, 19:26:27 »
i think you have just hit the nail on the head exactly that,
would it though only happen every now and again or would it be a permanent issue :-?
STMO123
Re: Please Advise
« Reply #6 on: 01 September 2007, 19:44:12 »
When mine failed the EML was off and on all the time, probably indicating that the wire was making and breaking. While the EML was off, all was normal.
Re: Please Advise
« Reply #7 on: 01 September 2007, 21:07:19 »
Did you checked fuel filter.. I checked haynes manual only this is left..
Although I think  crank sensor to be suspect haynes dont include it
« Last Edit: 01 September 2007, 21:09:40 by cem_devecioglu »
Crazydad
  • Germany
    • 2.5 V6 facelift
Re: Please Advise
« Reply #8 on: 01 September 2007, 21:42:34 »
I changed the Fuel Filter on it Today, i hoped  that that was the problem, thats why i did the paperclip test,
as already stated.
Re: Please Advise
« Reply #9 on: 01 September 2007, 22:42:50 »
then options are limited to sensors I think.
STMO123
Re: Please Advise
« Reply #10 on: 02 September 2007, 11:20:22 »
Crazydad
  • Germany
    • 2.5 V6 facelift
Re: Please Advise
« Reply #11 on: 02 September 2007, 11:20:40 »
Can anyone give me more Input on the Sensors,  :(
1.can i change them myself  :-? :-?:o :o
2. Are special tools required :-?
3. Where are they on the Engine :o :o
4.What sort of prices are we talking about :o
as the Paperclip test showed me both sensors were Faulty would the crankshaft sensor be affected by a faulty knock sensor, or do i need to change them both.
getting a little nervous about this as i am not to sure as of what to do.
JasonH
Re: Please Advise
« Reply #12 on: 02 September 2007, 15:23:25 »
Knock sensor is almost definitely damaged wiring. The wire is thin black coax and loops around the top of the engine so it's easily trapped. I'd suggest looking for damaged wire around the top of the engine. A tidy repair will probably fix it fine. The inner wire is supposed to be shielded by the out so a repair won't be perfect but it may well do.
To replace the sensor should only require a spanner but I believe access is a bit tight.
The crank sensor is about £50, but make sure you get the right one, there are 3 types. Vx prices here courtesy of MarkDTM http://www.omegaowners.com/forum/YaBB.pl?num=1164279437
Knock sensor info here: http://www.omegaowners.com/forum/YaBB.pl?num=1157560905
Crank sensor replacement information is here: http://www.omegaowners.com/forum/YaBB.pl?num=1174321688
Crazydad
  • Germany
    • 2.5 V6 facelift
Re: Please Advise
« Reply #13 on: 02 September 2007, 16:16:54 »
Thanks Jason  much appreciated :y :y
