Author Topic: bulb change help  (Read 1952 times)
bigup316
  • oxfordshire
bulb change help
« on: 30 August 2007, 20:06:49 »
how do i change the bulb for the electric sunroof controle try to gently pull the surround down but will not budge do not want to crack surround any idears must buy a haynes book i think
Re: bulb change help
« Reply #1 on: 30 August 2007, 20:39:08 »
pull knob down.  a bit of clear plastic (light guide) unclips, then if you have replacable bulb (not all are), it pulls out...
bigup316
  • oxfordshire
« Reply #2 on: 31 August 2007, 08:35:40 »
got clear plastic bit off after breaking one off the little clips but still nothing moves can not see bulb plastic bit will not stay on now but swich stays on and works does it matter that the clip is not on ware is the bulb ???????
« Reply #3 on: 31 August 2007, 10:37:30 »
some do not have user changeable bulbs - sounds like yours :(
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« Reply #4 on: 31 August 2007, 14:21:04 »
Hi im also need a new bulb in the sunroof dial.Can not get the knob to come off.mine  is a facelift would that have a diff way to get to the Bulb. :'(
Thanks for the help guys.
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #5 on: 31 August 2007, 19:29:33 »
The bulb on my sunroof control has never worked, did have a look at it but the tiny bulb is hard solderd onto the motor board and is a real bugger to do but it you want to do it then get a new led bulb and solder 2 long legs to it and then solder the new legs to the original.fiddly but doable. ::)
Jaguar XJ6
bigup316
  • oxfordshire
« Reply #6 on: 02 September 2007, 23:53:53 »
how do i get the sunroof plastic off to put another bulb on cicuit board thanks
« Reply #7 on: 03 September 2007, 10:49:56 »
pop the courtesy light out, 2 screws there, then it should unclip...
Markjay
  • London
« Reply #8 on: 03 September 2007, 13:28:34 »
Sorry slightly off-topic, but does everyone have very very very dim backlight on the main lights control knob, to the extent that it can only be noticed when parked inside mountain cave on a moonless night?  :o
Alas, no more Omegas....
Dazzler
  • Haverhill, Suffolk
« Reply #9 on: 03 September 2007, 14:47:02 »
Yep....
Markjay
  • London
« Reply #10 on: 03 September 2007, 14:49:48 »
Yep....
Ahhh... no point in me getting the thing out and taking it a apart then...
philayl
  • Wirral, Merseyide
« Reply #11 on: 03 September 2007, 15:38:32 »
I bought a control off Ebay that had been modified with the blue LED's, now that you can see, even in daylight! In fact I liked it so much I changed all the fascia switches, the gearshift indicator and all the window switches for the blue LED's.
