Author Topic: Autobox newbie questions  (Read 1930 times)
ians
  • Reading
« on: 02 September 2007, 09:25:40 »
First time with an autobox fluid change..
I have a few questions would appreciate any advice from those who've been there before me :y
- Filter
I understand that its possible to clean and reuse the filter.  Haynes mentioned 'solvent' and I think someone on here used white spirit.   What is recommended?  Obviously I don't want to leave any residue which may harm the new Dex 3.
Haynes also mentions a 'seal' .  Is this a small oring type affair that sits around the key slot hole in the top of the filter?  If so, this remained on the main body of the transmission - there are traces of glue on the filter.   Does this mean I need a new filter, as BoL says the seal is not available on its own..?
- oil
I drained about 5L out including both sumps.   Is that about right?   If I get 6L to refill, will that be enough?
- gaskets
been using a paint scraper to remove the old gasket from the sumps and body - its hard going to remove all the crap esp. as some of the gasket is stuck to the sump rim in between the two sumps.  Is there a solvent that will clean up the surfaces nicely?
Cheers,
Ian
Re: Autobox newbie questions
« Reply #1 on: 02 September 2007, 19:20:54 »
The seal on the filter is a small 1" square piece of cork with a hole in...
5l out sounds about right - it holds 8 - 9l, only half comes out...
ians
  • Reading
« Reply #2 on: 02 September 2007, 19:56:46 »
Thanks TB :y.  The seal seems to be in good nick although attached to the main body rather than filter.  Think I'll just leave it in situ with a dab of gasket goo if I can clean the filter ok.
Petrol seems to disolve Dex3 so will try that to clean the filter.
Markjay
  • London
« Reply #3 on: 02 September 2007, 21:03:19 »
Some people here bought the filter from www.jpat.co.uk , my understanding is that it is this item:
and that the cost is around £30 , might be worth just changing it while you're there...
See also:
http://www.omegaowners.com/forum/YaBB.pl?num=1187589256/3#3
« Last Edit: 02 September 2007, 21:03:46 by markjay »
Alas, no more Omegas....
devonian
  • Sunny South Devon
« Reply #4 on: 02 September 2007, 21:41:01 »
Hi there
I have bought autobox filter from JPAT
N209 27 01 VAUX FILTER 44MM 4L30E is the part number and only cost me £17.95 exc VAT!
Give them a call as they are very helpful  :)
« Last Edit: 02 September 2007, 21:42:22 by devonian »
Omega 3l Elite
sassanach
  • trowbridge
« Reply #5 on: 02 September 2007, 21:47:31 »
do not put "gasket goo" on the filter
ians
  • Reading
« Reply #6 on: 03 September 2007, 17:54:28 »
I meant loctite gasket compound on the filter gasket.   but I doubt it's needed as the gasket looks ok.  don't particularly want to change the filter for no good reason.
