Author Topic: Omega Specialist near Milton Keynes  (Read 4754 times)
road_rescue
  • Concrete Cow County
« on: 15 August 2007, 09:59:44 »
Help!
The darn thing has gone wrong again!  :'(
This time its now developed a missfire. I give up, I can't work out whats wrong with it!
Can anyone recomend a good garage/mobile mechanic near Milton Keynes that could have a look at it?
If not, anyone here want to take a look for tea/beer/money? (delete as appropreate!)
With sufficient thrust, pigs fly just fine.
Dazzler
  • Haverhill, Suffolk
Re: Omega Specialist near Milton Keynes
« Reply #1 on: 15 August 2007, 11:11:58 »
Have you checked the spark plugs, leads and finallt the Dis pack?????
« Reply #2 on: 15 August 2007, 13:40:30 »
I am based in Brackley, ok check the basics, plugs, leads? done a paperclip test?
« Reply #3 on: 15 August 2007, 18:03:59 »
Jim Grayson.
road_rescue
« Reply #4 on: 15 August 2007, 22:15:12 »
being a biff now- paperclip test?
« Reply #5 on: 15 August 2007, 22:17:03 »
See FAQ section
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
« Reply #6 on: 15 August 2007, 22:31:50 »
If DIY is not 4u I  would have a day out to Bedford and visit ??????????????
http://www.externalserver.me.uk/dave.nsf/aboutus!OpenPage
Example:
Say's V6 cam belt kit supplied & fitted  for £250.00.
Which is a lot cheaper than dealer quotes
« Last Edit: 15 August 2007, 22:39:54 by iggy21uk »
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
road_rescue
« Reply #7 on: 15 August 2007, 22:57:51 »
See FAQ section
Ta- soon as I hit send I realisd what you meant...
« Reply #8 on: 16 August 2007, 01:24:18 »
Example:
But still double what I would charge ;)
« Reply #9 on: 16 August 2007, 08:25:50 »
As I said earlier, Jim Grayson in MK has an excellent reputation if you are getting nowhere, and does seem to know these engines well.....
Do NOT use those muppets at Evans Halshaw/Crownhill Vauxhall - they are incompitent.
BazMV6
  • Silverstone
« Reply #10 on: 16 August 2007, 09:50:01 »
From ~15 years experience of having to take company cars there, I agree with this sentiment.  >:(
They used to be know as Cowboy & Wilson...   ;)
« Last Edit: 16 August 2007, 09:50:58 by BazMV6 »
This space left blank for your own message...
road_rescue
« Reply #11 on: 16 August 2007, 10:23:28 »
thanks for the pointers guys- i will let you know how i get on over the weekend!
road_rescue
« Reply #12 on: 18 August 2007, 12:17:11 »
Paperclip test done-
12
145 - Might have something to do with the power sounder being removed :)
19 - Crank sensor; would that make it run like a dog?
How do i change the crank sensor then?
« Reply #13 on: 19 August 2007, 00:03:57 »
12
145 is immobiliser, seems to be code that never seems to erase itself.  Real prop is the 19, so change it immediately.
On V6, its just near oil filter. 4 pots hide it behind ac compressor.
road_rescue
« Reply #14 on: 02 September 2007, 14:10:48 »
4 hours later- crank sensor changed, oil changed, fliter changed.
still runs like a bag of poo.
HELP!!!!
