Author Topic: Water in cabin  (Read 5300 times)
caolan_p
  • IRELAND
Water in cabin
« on: 04 September 2007, 22:34:11 »
hello people just new tonight ,and trying to get the hang of ,well anyway i have a 2001 omega 22 cd so far the car is great ,best car i have had , one prob was driving in very rain and a water top came on at the passenger side ,yes his feet got soaked ha ha , i cant & dont no how it got in .any thoughts please reply thanks . :)
« Last Edit: 04 September 2007, 22:46:18 by TheBoy »
Re: Water in cabin
« Reply #1 on: 04 September 2007, 22:47:00 »
Welcome to the site :)
Likely come in through pollen filter. Make sure scuttle drain is clear.
miggy
Re: Water in cabin
« Reply #2 on: 04 September 2007, 22:53:59 »
Same thing happened to me on the other miggy, TB is correct, the drain is directly under the pollen filter to the left of it as you look into filter area, mine was solid and the water came in as it was filling up the compartment.
 :y :y
hotel21
  • The Kingdom of Fife
Re: Water in cabin
« Reply #3 on: 04 September 2007, 23:04:50 »
Needs cleared out, bud.  You run the risk of knackering the aircon controls if left to drip and get wet.  Either a wet and dry vacuum cleaner to suck out the crap or run the risk of backlash when using a power washer down the pollen filter lower regions when blasting it clear.  Don't wear white trainers as it will drip onto your shoes.......   :-[
Remember to replace the filter as well as its FUBAR'ed if it gets wet.....   :y
« Last Edit: 04 September 2007, 23:06:32 by hotel21 »
ians
  • Reading
Re: Water in cabin
« Reply #4 on: 04 September 2007, 23:08:36 »
here you go..
http://www.omegaowners.com/forum/YaBB.pl?num=1167524083
get some chips on as you will likely find some fish in there  ;D ;D
caolan_p
  • IRELAND
Re: Water in cabin
« Reply #5 on: 04 September 2007, 23:09:13 »
thanks for the replys .do i get to the polin filter through the bonet at the top right hand side ? done a service and the only thing i missed was the polin filter .will check it out , if i find it . :) :)
miggy
Re: Water in cabin
« Reply #6 on: 04 September 2007, 23:16:14 »
You got me thinking now about the issue with my air con, has the same happened to mine in the past.
 :o :o
hotel21
Re: Water in cabin
« Reply #7 on: 04 September 2007, 23:18:36 »
Standing at the front of the car, pollen filter is located up and to the right, under the splash guard where the wiper stalks come out of the car.  Theres a rubber weather strip runs left and right across the car above the bulkhead.  At the extreme right endyou will see a lift up panel.  Filter is hiding under there, water is a few inches below.  A torch may be required.....    ;)
hotel21
Re: Water in cabin
« Reply #8 on: 04 September 2007, 23:19:22 »
 :o :o
Strong chance........   :'(
miggy
Re: Water in cabin
« Reply #9 on: 04 September 2007, 23:23:12 »
 :o :o
Just been out and looked, the compartment has about 3 inches of water in it, I put a metal coat hanger down there and pulled out a hand full of leaves, checked the carpets on the passenger side, the sponge underneath is wet, not soaking, just damp, do you think this may be the prob with the air con, but surly the electrics are sealed in some way as not to allow water on them.
« Last Edit: 04 September 2007, 23:24:02 by miggy »
hotel21
Re: Water in cabin
« Reply #10 on: 04 September 2007, 23:27:44 »
 :o :o
Yes, no and no....... :'(
Get rid of the water and crud as, when it overfows into the cabin, not only does it soak the carpet and stink it can and does burn out the aircon speed controller as its not waterproof.  First step to get rid of the cr*p and let it dry out.  You may need another aircon fan speed motor (or similar gubbins....) .  Someone more cleverer may confirm or assist........ :-/
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
Re: Water in cabin
« Reply #11 on: 04 September 2007, 23:28:07 »
It's about 19" x 12" and is held in place by a clip on both sides towards the top.  The front panel will then drop forward and you can slide the filter out.  Yours originally should have been a grey carbon one but Vx may try and sell you a white flimsy one for a pre '99 car.  The part no you need is 93165208 .... £14.80 retail.... £10.78 on Trade Club - my dealer never has them in stock so you may have to pre-order.
The blocked drain empties into your engine bay - but be careful if you poke around with a screwdriver as there may be electrical wiring down there too.  The rubber grommet is about 2" in diameter and can be helped along from the engine bay once located. HTH  :y
Re: Water in cabin
« Reply #12 on: 05 September 2007, 09:00:05 »
The fan and it's speed controller would be in the path of water coming in by design (fan needs to be there obviously, speed controller mounted there for airflow.
Obviously, water should not come in this way, and is a result of people not taking care of their car.
miggy
Re: Water in cabin
« Reply #13 on: 05 September 2007, 09:13:07 »
With the amount of crap I took out of the drain obviously the previous owner did not.
caolan_p
  • IRELAND
Re: Water in cabin
« Reply #14 on: 05 September 2007, 11:02:02 »
hello people i checked my polin filter and yes its stinkin and full of water ,got the water out all dirt at the bottom is that were the drin is ,going to get a new fiter will it stop the water .thanks ;)
