Author Topic: rocker caskets  (Read 2129 times)
fatboy
  • newport  south wales
rocker caskets
« on: 05 September 2007, 23:48:26 »
hi all is there a good casket sealent out there or will it be alright just with caskets :)
Paul M
  • Edinburgh
Re: rocker caskets
« Reply #1 on: 06 September 2007, 00:14:56 »
Gaskets ;)
Use only genuine VX gaskets and BLACK sealant... it's important to use the right stuff or you'll be doing the job again.
There is a how-to in the maintenance guides section, which has part numbers.
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: rocker caskets
« Reply #2 on: 06 September 2007, 00:16:29 »
The black stuff from Vaux is what is recommended, and use genuine gaskets the pattern ones aren't as good and will leak. See the maintenance guide section for a how to.
TuBy's new whipping boy.
Markjay
  • London
Re: rocker caskets
« Reply #3 on: 06 September 2007, 08:03:32 »
If you get all original GM parts, i.e. gaskets, o-rings, and sealant, and strictly follow the maintenance guide, then you might get two or three years of leak-free camcovers... any deviation from that, e.g. non-original parts or other shortcuts, and you will need to redo the job in less than 3 months.... good luck with it and keep in mind help is available on this site if you need it.
Alas, no more Omegas....
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: rocker caskets
« Reply #4 on: 06 September 2007, 08:12:19 »
...and do both sides. even if you think only 1 needs work. Murphys Law dictates...
hotel21
  • The Kingdom of Fife
Re: rocker caskets
« Reply #5 on: 06 September 2007, 09:07:07 »
...... and clean out the breather system first.  If the internal engine fumes do not have anywhere to go when the breathers are blocked, they can force oil out through the camcover gaskets, hence the leaks.  Sometimes if the leak is not too bad, simply doing a breather clean (again, howtoo in maint guides) will reduce/stop the leak.
Also, clean out the old oil from the plugwells as it affects the spark plug caps, breaking down the insulation and leading to misfire probs......  :y
Paul M
  • Edinburgh
Re: rocker caskets
« Reply #6 on: 06 September 2007, 10:58:35 »
Good advice. I was originally only going to do one of mine (driver's side) as it was clearly shot and the other one looked OK. I decided I'd do both anyway and I'm glad I did as the passenger side one was almost as bad, it just wasn't noticable before taking the plug leads out.
Markjay
  • London
Re: rocker caskets
« Reply #7 on: 06 September 2007, 11:21:00 »
