Author Topic: Paper clip test still no go  (Read 4890 times)
Grumpy
  • Manchester
Re: Paper clip test still no go
« Reply #15 on: 05 September 2007, 19:02:16 »
Motronic uses same pins on diag socket as Simtec
Agreed. But nuclear_onion is counting the pins differently, and I think he
got the right pins to link accidentally because 4&5 are linked.
Hope I'm making sense here on what I'm on about.  :)
« Reply #16 on: 05 September 2007, 19:19:22 »
Makes sense.  Short either 4 and 6 or 5 and 6. 4 and have should be connected together anyway.
holey head
  • leeds uk
  • i'm a new dad
« Reply #17 on: 05 September 2007, 19:36:45 »
any codes stored???
ouch my head hurts! i'll try and remember to wear my helmet next time i'm out on the quad!
« Reply #18 on: 05 September 2007, 19:45:13 »
any codes stored???
Mine? Yes  :-[
Just waiting for the vid to upload so i can write a maint guide.
holey head
  • leeds uk
  • i'm a new dad
« Reply #19 on: 05 September 2007, 20:46:53 »
go on then jaime, what codes are stored??????
« Reply #20 on: 05 September 2007, 21:13:20 »
See the Maintenence Guide.... ;)
johnc46
  • Shevington Wigan
« Reply #21 on: 05 September 2007, 21:39:52 »
WOW have I opend a bag of snakes,  tell me when its sorted  :-/ :-/ :-/
nuclear onion
  • Derbyshire
« Reply #22 on: 05 September 2007, 22:00:31 »
The link I put up before doesn't seem to work but this one should, http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm This was were I got my info from including how to work out how the pins are numbered.  According to them, the plug in mine is for a simtec but it must actually be motronic because out of the lists of codes for all the diffenent varients motronic were the only ones that matched what mine actually flashed out.  They also show different pins to connect to the ones in The Boy's picture which were the ones I used so it shouldn't have worked but it did and I have no explanation for that.
I did make a mistake about which number pins to connect. They put 5&6 NOT 4&6.  I just read it wrong, sorry.  Go check out the link and see what you reckon cos I don't get how they can get it wrong yet it still worked.
Never drive faster than your Angel can fly
« Reply #23 on: 05 September 2007, 22:03:49 »
topbuzz does have a lot of inaccuracies....
v6 engines are motronic, 4 cylinder petrols are simtec.  All Omegas use the 16pin OBDII connector (though on post 2001 are actually OBDII protocol compatible).
nuclear onion
  • Derbyshire
« Reply #24 on: 05 September 2007, 22:09:24 »
Now it makes sense :)
Lordmpl
  • Norwich, Norfolk, UK
  • 2.5 V6 Auto CDX - Big Bertha
« Reply #25 on: 06 September 2007, 12:10:37 »
I have a 2.0ltr 16v with the Simtec 56.5 plug and use the 5&6 pins, the other pins dont work on mine.
I just plug in the paperclip and turn on the ignition, then it starts flashing.
Now i have cleared mine, i just get the code 12 repeated, which is good..
Thanks, mark  :y
I Love my Omega, wanted it for so long, now it's in my grasp, it's not getting away!!
