Author Topic: Oil cooler sealent  (Read 1620 times)
Dazzler
  • Haverhill, Suffolk
Oil cooler sealent
« on: 06 September 2007, 08:46:05 »
What is the correct sealant to use for the oil cooler plate???? Does anyone have the p/n's for the oil cooler and seals please.
TIA.
hotel21
  • The Kingdom of Fife
Re: Oil cooler sealent
« Reply #1 on: 06 September 2007, 08:59:09 »
Had a play with the search button under the forum logo at the top of the page and turned up the following in various posts.  Hope it helps and hopefully someone will double check for me before you go and part with the dosh....   :y
Part Number                                       List £                         Net v                      Amount
1 X 93176626 Radiator Engine            90.50                        81.45                         81.45
1 X 93165267 Sealing compound          7.80                          7.02                           7.02
4 X 11076852 Seal ring T                      .44                            .38                           1.52
4 X 12992647 Seal ring T                     1.55                          1.41                           5.64
2 X 90501652 Seal T                           10.65                         9.59                         19.18
3 X 90501653 Seal T                            9.00                          8.11                         24.33
1 X 9118135 O-ring set T                     10.55                         8.97                           8.97
B
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #2 on: 06 September 2007, 12:10:51 »
B
Spot on - and having done this job that sealant is a right PITA to get out, best put in a "gun"
Oh and dont read the warnings on the back of it - they will scare you
Markie
« Reply #3 on: 06 September 2007, 12:11:27 »
also dont reuse or overtighten the hollow bolts they are very fragile - sorry dont have part number right now for them
« Reply #4 on: 06 September 2007, 12:30:47 »
B
I never read them, only read instructions when you are stuck!
The oil cooler plate has a low torque setting, i invested in a torque wrench to get it right.
I used a standard 'gun' for pastes, came out very smoothly for me, no issues.
When fitting:
Put the oil cooler in first, then the plate without sealent. get the cooler in the right place, remove plate, gunk up and re-fit, using your clean fingers in the oil cooler as a guide. Insert it at an angle towards the passenger bank, then down. It will go in smoothly that way....  :y
Markie
« Reply #5 on: 06 September 2007, 12:50:07 »
....oh its not the instructions its the warnings and side effects...and that the product is outlawed in California  :o
sassanach
  • trowbridge
« Reply #6 on: 06 September 2007, 13:17:58 »
i used bog standard hermetite silicone sealer on mine.
« Reply #7 on: 06 September 2007, 14:07:35 »
I have seen this used before......and I was re-sealing it as a result!
That sealent they spec is evil stuff.......you want to try removing the sumps when they have been stuck on with it!
Dazzler
« Reply #8 on: 06 September 2007, 18:51:44 »
Thankyou all for your advice. I am glad i took the p/n for the cooler as without that OLD p/n i would have had to pay £236 instead of £90 ::)
Many thanks
