Author Topic: auto box  (Read 2204 times)
craykent
  • abergavenny south wales
auto box
« on: 06 September 2007, 19:05:26 »
Hi just had my 2.5td shut down on me moving slowly engine cut out computor came up GEARBOX FAULT . sat there stunned when I came to turned off the key then turned it on again started an run ok since done 20 miles home with very tight buttocks  !! seems to be running ok as usual have owned the car for 2 3/4 years serviced often by myself  any ideas would be grateful thanks
Re: auto box
« Reply #1 on: 06 September 2007, 19:48:22 »
check the fluid level in the box, it's very possible its on the way out.
AR25's are fitted to 2.5TD's and they all go bang around 120k miles - If you do replace the box, make sure its an AR35 as they are much stronger
« Last Edit: 06 September 2007, 19:48:39 by tunnie »
Grumpy
  • Manchester
Re: auto box
« Reply #2 on: 06 September 2007, 19:58:01 »
All I can tell you, seeing as it's an Auto and the engine actually stalled, is
that it's not necessarily a Gearbox fault.
Being an auto, there is a fluid drive between the Engine and the Gearbox,
not a direct mechanical link. So there can be some variance between the
input and output speeds of the gearbox.
The ECU will have a set of parameters built into it, an operating envelope if you
like. If these parameters are exceeded, it will put the gearbox into Limp manual
mode.
When my Crank sensor was playing up, sometimes the engine would try to stall,
revs drop down, road speed normal. If it recovered without actually stalling,
the gearbox fault light would come on and the go into manual operation only.
All would reset on a restart.
Not saying this is what happened to you, but bear it in mind and don't automatically
condemn the Auto box.
There are some chaps on here that are on intimate terms  :) with every nut, bolt,
and widget on the diesels, and I'm sure they'll be along soon with a check list
for you to carry out.
miggy
Re: auto box
« Reply #3 on: 06 September 2007, 20:14:28 »
Whats fitted on the 2.6 V6 :question :question
Martin_1962
Re: auto box
« Reply #4 on: 06 September 2007, 21:17:42 »
AR25
miggy
Re: auto box
« Reply #5 on: 06 September 2007, 21:21:44 »
AR25
What are the AR 35s fitted to, the 3.2s, when it said they go bang, does it refere to the gearbox is stuffed.
hotel21
  • The Kingdom of Fife
Re: auto box
« Reply #6 on: 06 September 2007, 21:28:15 »
Dunno for sure but theres a fair bit on the forum already.
Tech Info - http://www.omegaowners.com/forum/YaBB.pl?num=1183545930
but more likely, this in maintenance guides - http://www.omegaowners.com/forum/YaBB.pl?num=1183142571
Re: auto box
« Reply #7 on: 06 September 2007, 22:02:37 »
If the engine stalls, its not uncommon to get a false 'gearbox fault'...
Worth doing the fluid and filters as a matter of course...
craykent
Re: auto box
« Reply #8 on: 06 September 2007, 22:28:24 »
Thanks for your suggestions i have just been out again [ priorority club meeting ] i will check fluids asap  ;) this weekend if i can pinpiont the cause i will post back findings   :-?
Re: auto box
« Reply #9 on: 06 September 2007, 23:54:05 »
Gearbox fault will also appear if you were to forget to fit the throttle position doo-dar after you've done your cam belt change ..... apparently ::)  ::)
;D  ;D  ;D
