Author Topic: Exploding Egr  (Read 4627 times)
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Exploding Egr
« on: 07 September 2007, 16:28:04 »
BUGGER  :o has any one had an egr valve come apart on the 2.5 before  :question  I was on my way to sort out my brake discs (thats another story) and had two problems first of all some woman decided she was going to try to remove my wing mirror with hers   >:( apparently she did not realise that the island part of the road calming feature that was on her side of the road meant she was meant to give way to me and tried to come through as I was. luckily they just clipped and no damage done  :y Anyway after this off i go again and get behind someone on a Sunday afternoon drive (I know its not Sunday  :P) so I decide to pass and boot it no problem, then as I get past drop back to speed limit and notice a strange tone to the engine and slight power loss . No raised temp no eml so carry on sort thr discs out the car is not happy starting but then started and seemed to be a bit rough idling etc on the way home eml flashing on and off but not on constantly just checked and found that the egr seems to have sheared the three bolts that hold its body together which I am assuming is giving me the problem . I  have read that the egr can be left disconnected and blanked off is that correct. Until I can find a replacement
LFF64
  • HADDENHAM BUCKS
Re: Exploding Egr
« Reply #1 on: 07 September 2007, 16:28:43 »
Sorry that was a bit long  ::)
IrmscherKris
  • Manchester
  • banned due to bad trader references
Re: Exploding Egr
« Reply #2 on: 07 September 2007, 16:31:45 »
Yeah, block it off - EGR's are for wimmins anyway  :y
ians
  • Reading
Re: Exploding Egr
« Reply #3 on: 07 September 2007, 16:38:56 »
that's very common.  I have had two go on me.
I'm interested to know how to blank it off and what to do with the electrical connector - if you don't remove it you need to stop it rattling around somehow - I wired mine up (assume a cable tie would melt) but a bit less than ideal.
LFF64
  • HADDENHAM BUCKS
Re: Exploding Egr
« Reply #4 on: 07 September 2007, 17:06:09 »
It looks like a sealed unit to me so there apears to be no way of replacing the screws But it was too hot to do anything with when I got in so I will hold it on using a jubilee clip and pop in to work and see what i can sort out. I will look at where the connector goes and see if it will go anywhere. Will the egr not being connected affect anything onn the ecu I do not want the eml light to be on after its disconnected
LFF64
  • HADDENHAM BUCKS
Re: Exploding Egr
« Reply #5 on: 07 September 2007, 18:23:01 »
Ok, I have blanked the egr valve off by removing the base section held down with the torx bolts. Basically all I have done is cut a plate from a bit of stainless steel,not sure if it was 1.5 or 2mm thick long enough to cover the two exposed holes that were under the base plate as I to get the car going again I have placed this plate under the base and just bolted it back down and it appears to be running ok  :y actually it seems to be running a bit better than before  :y Only problem is the eml is now on which it was not before will this clear on its own  :question
hotel21
  • The Kingdom of Fife
Re: Exploding Egr
« Reply #6 on: 07 September 2007, 18:29:34 »
As far as I recall, as long as its blanked and the electrical connection is still in place then no fault light should be displayed?   :-?
LFF64
  • HADDENHAM BUCKS
Re: Exploding Egr
« Reply #7 on: 07 September 2007, 18:43:38 »
I have not left it connected elecrically  :-/
LFF64
  • HADDENHAM BUCKS
Re: Exploding Egr
« Reply #8 on: 07 September 2007, 18:45:35 »
Whoops meant to ask if it is connected back up will this reset the eml then or is that a tech2 reset only
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Exploding Egr
« Reply #9 on: 07 September 2007, 19:14:29 »
Usual method is to replace the metal gasket with a piece of sheet without the holes as you have done.
Then replace EGR leaving it connected electrically. I believe replacing electrical connector will remove the light.
TuBy's new whipping boy.
hotel21
Re: Exploding Egr
« Reply #10 on: 07 September 2007, 19:14:52 »
Dunno!  Plug it back in whilst the valve is blanked and see what happens....  If still lit then may well need a tech2-ing....   :y
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Exploding Egr
« Reply #11 on: 07 September 2007, 19:22:11 »
Look on the bright side, at least you got TB on your doorstep if needed. Hotel21 is the best part of a days drive from decent Tech2 services.
LFF64
  • HADDENHAM BUCKS
Re: Exploding Egr
« Reply #12 on: 07 September 2007, 19:22:25 »
I will plug it back in tomorrow I left it in my toolbox at work earlier. Production are in on overtime in the morning so I have to go in just in case so I  will be getting paid overtime for working on my car as I am replacing front discsetc while I am there  ;D As I pointed out to the boss I can not be on call as the car wont be on the road  :y
LFF64
  • HADDENHAM BUCKS
Re: Exploding Egr
« Reply #13 on: 07 September 2007, 19:25:43 »
Yes he is about ten min down the road from me, I am thinking about using his services in the not too distant future gearbox climate etc  ;D
Re: Exploding Egr
« Reply #14 on: 07 September 2007, 20:34:52 »
EGR needs to left plugged in electrically.
