Author Topic: Exploding Egr  (Read 4635 times)
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: Exploding Egr
« Reply #15 on: 07 September 2007, 20:38:51 »
Hello TB oh wise one  ::) is that enough grovelling  ;D when I reconnect it will the eml eventually go out again on its own :question
Re: Exploding Egr
« Reply #16 on: 07 September 2007, 20:40:16 »
Should go out fairly quickly after reconnecting, ie next start...
LFF64
  • HADDENHAM BUCKS
Re: Exploding Egr
« Reply #17 on: 07 September 2007, 20:46:25 »
Right last one on this promise  ;) will having the eml on effect the car it seems to be going really well with it on, its just that I thought if the eml is on it resticts the engine to safe mode or does that only happen on certian sensors etc and this is not one of those sensors  :-?
Re: Exploding Egr
« Reply #18 on: 07 September 2007, 20:53:18 »
Not sure the egr will cause the engine to limp  :-/
LFF64
  • HADDENHAM BUCKS
Re: Exploding Egr
« Reply #19 on: 07 September 2007, 20:59:19 »
It certainly does not appear to be  ::) Thanks for the advice everyone I was worried I had killed it earlier on this afternoon but thanks again to OOF it will live and not even cost anything to fix even better  :y
Re: Exploding Egr
« Reply #20 on: 07 September 2007, 21:47:31 »
When EGR is blocked you will get better power, better mileage from fuel..
Re: Exploding Egr
« Reply #21 on: 07 September 2007, 21:49:26 »
mpg might drop a bit when cruising....
LFF64
  • HADDENHAM BUCKS
Re: Exploding Egr
« Reply #22 on: 08 September 2007, 09:47:10 »
Good morning all out there  :) right I have reconnected the remains of the egr to the connector and the EML has gone out , so yes it does need to be left connected . I  have managed to find another good valve (Thank you Henry at las_jacarandas :y) and I will fit this when it arrives I know everyone seems to think its ok to blank them  :) but why would it be there if its not needed . Anyway as I said thanks for all the help on this I was really worried something major had happened to the car yesterday afternoon espsecially when it would not start and was running really bad when it did fire up then the eml flashing on/off  :o I just hope everyone else can get sorted as easily as I have  :y
Re: Exploding Egr
« Reply #23 on: 08 September 2007, 09:58:02 »
Its needed for emissions (which aren't checked), so not really required.  Does (marginally) improve mpg whilst cruising.
LFF64
  • HADDENHAM BUCKS
Re: Exploding Egr
« Reply #24 on: 08 September 2007, 10:16:33 »
I have just brought a s/h one for £15 delivered so its worth refitting rather than having it cable tied to the air box as it is at the moment  ::)
Thank you las_jacarandas  :y
Re: Exploding Egr
« Reply #25 on: 08 September 2007, 10:18:28 »
Worth fitting at that sort of money, just so everything is 'right'.
