Author Topic: heaters...no direction  (Read 1352 times)
barlow
  • geordieland
« on: 08 September 2007, 20:15:34 »
Hi guys, thanks for the welcome and advice to air my problem here. Omega 2l GLS, the heater direction control ceased to direct airflow through the designated vents. The fan is ok but air just blows behind the dash area. Inspection behind the control panel showed the vacuum pipes seemed ok. Winter looms so any advice or ideas would be very welcome. Cheers from Geordieland.
Re: heaters...no direction
« Reply #1 on: 08 September 2007, 20:17:38 »
There is a engine vac pipe diagram in Omega info section - worth checking as a first port of call...
barlow
  • geordieland
« Reply #2 on: 08 September 2007, 21:23:01 »
thanks theboy, will try to ckeck it out.
