Author Topic: 3 button omega key fob  (Read 2678 times)
allyw71
  • fife, scotland
« on: 08 September 2007, 17:41:47 »
I'm needing to replace my key fob, I believe there are two frquencey's available but I don't know what they are or which one to get, can anyone help please, the cars a 2001 3.0 elite saloon with anti-theft,
thanks
           Alistair
VX1
  • Reading, Berkshire
Re: 3 button omega key fob
« Reply #1 on: 08 September 2007, 17:46:03 »
You will need the three button key fob. If you get a replacement off of ebay all you need to do is take your chip out of your pad and put into the new one. No need to get new fob coded then job done.
Cheers Paul  :y
Vx Trade club card holder
Halfords trade card holder
allyw71
  • fife, scotland
« Reply #2 on: 08 September 2007, 17:55:24 »
thanks for reply Paul, but the switches are coming adrift from the circuit board, hence I need the whole thing and re-pogramming
VX1
« Reply #3 on: 08 September 2007, 18:01:26 »
The chip is the part that gets programmed. You can take the chip out and put it in the new fob. I do take it that the fob is part of the key and can be separated from the key? Is it like this one?
http://cgi.ebay.co.uk/VAUXHALL-VECTRA-OMEGA-etc-3-button-REMOTE-ALARM-KEY-FOB_W0QQitemZ300148463402QQihZ020QQcategoryZ10404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
If so then the fob part can come away from the key, so all you will need is to take the chip out and put in the new fob.
    • 530D M Sport, 330i Coupe
« Reply #4 on: 08 September 2007, 18:10:51 »
The chip is for the engine immobiliser and can be moved, however the fob will need programming if you replace it.
allyw71
  • fife, scotland
« Reply #5 on: 08 September 2007, 18:18:20 »
yes, but its not as simple as that, i've already bought one in very good condition and previously tried what you said with no joy, it will start the car but wont opperate the door/boot locks, so i took it to vx for programming, they tried and failed because it works of a diffrent frequency and wouldn't accept the code for my car,
« Reply #6 on: 08 September 2007, 18:33:03 »
Wasn't aware that their were different frequencies on the three button ones. TheBoy should be able to help you on this one.
allyw71
  • fife, scotland
« Reply #7 on: 08 September 2007, 18:56:41 »
just pulled both fobs apart and the circuit boards look very different, on closer inspection (with a magnifying glass) my original one has 92MHz on it, the other one doesn't have any frequency markings, so i think that's my question answered.
 Thanks all
                 Alistair
    P.S. anyone want to buy a 3 button fob thats not 92MHz v.g.c.
« Reply #8 on: 08 September 2007, 19:21:26 »
It needs to be the same make (and type) as your working one.  For facelifts, its usually Delphi or Bosch, but you need to check which.  Written on back of fob, if its readable.
« Reply #9 on: 08 September 2007, 20:23:02 »
Can you tell if it's Delphi or Bosch?
Says on the square panel on the back of the key if not worn away.
allyw71
  • fife, scotland
« Reply #10 on: 09 September 2007, 00:42:33 »
no its worn away on both of them
davlad22
  • Sunny Yorkshire
« Reply #11 on: 09 September 2007, 08:56:20 »
Never seen a 3 button one on omega. Does it operate the boot for a saloon then? We purchased a 2-button brand spanker with one of our cars recently, I believe cost was around £55 for the fob and £10 for the auto locksmith/technician to program it.
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
« Reply #12 on: 09 September 2007, 10:00:44 »
Mines only a two button for 99 yaer car. Nothing on the case now but says in small print on the cct board
Megamos 92mhz. So your may have it  printed on the cct board???
« Last Edit: 09 September 2007, 10:15:03 by iggy21uk »
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
« Reply #13 on: 09 September 2007, 10:10:12 »
Facelifts are 3 button (as there is no other way to open the boot unless you are in the car).
Remove kick panel, drivers side - see what make the alam ecu is.
