Author Topic: warning noise  (Read 2712 times)
spurno
  • torquay
warning noise
« on: 07 September 2007, 19:30:26 »
a noise has started today for no apparent reason.it appears to come from around the brake m/cyl area.it sounds constantly,with ignition on or off.the noise is just like a twittering bird.i've checked the fusebox but can't find anything there.also happens with the ignition key out and car locked.everything else seems to be working as normal.obviously i'm worried about the battery running down and with the wife having recently been ill,i don't want it conking out on her.any help please.
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: warning noise
« Reply #1 on: 07 September 2007, 19:37:23 »
I may be wrong but that could possibly be the alarm power sounder dying it is in that area under the scuttle trim you could have a look and then if it is there disconnect the connector to it apparently the rechargeable batteries pack up on these units
hotel21
  • The Kingdom of Fife
Re: warning noise
« Reply #2 on: 07 September 2007, 19:42:38 »
Agreed, power sounder is the culprit.
Use the search button under the OOF logo on the top of the page and have a trawl of posts.  There are a few threads covering this.   :y
spurno
  • torquay
Re: warning noise
« Reply #3 on: 07 September 2007, 19:51:12 »
thanks guys.do i need to get new rechargable batteries?
LFF64
  • HADDENHAM BUCKS
Re: warning noise
« Reply #4 on: 07 September 2007, 20:10:15 »
Hello again I think you will find they are a sealed unit and not replaceable as Hotel21 said try doing a search for the power sounder it has been covered a fair bit. We are not just trying get you to do this to to fob you off just that you will find loads of information already covered about these that you can browse through Hope this helps
hotel21
Re: warning noise
« Reply #5 on: 07 September 2007, 20:13:34 »
 :y   ;)
spurno
  • torquay
Re: warning noise
« Reply #6 on: 07 September 2007, 20:13:35 »
i've had a look in the search area and it did help,thanks.just didn't know if the batteries could be changed because you said they were rechargable.
old cruiser
  • Slough
Re: warning noise
« Reply #7 on: 07 September 2007, 20:41:30 »
They are chargeable batteries, but trying to get hold of them is a nightmare and there was only one company that I think someone came across but unfortuneatly they've stopped doing them!! cost new for power sounder from Vx is around £50 mark and is probably a better bet and when I changed mine I ripped the old one apart and it had Ni-Cad Batts fitted and the new ones have Ni-mh so less chance of the memory effect  compared to the Ni-cad ones.
Cheers Pete
spurno
  • torquay
Re: warning noise
« Reply #8 on: 10 September 2007, 15:56:09 »
i know it's a couple of days on now but it hasn't happened since.strange.
hotel21
Re: warning noise
« Reply #9 on: 10 September 2007, 16:02:12 »
Perhaps the batteries are now taking and holding a charge for some reason.  Has the car been laid up for a while and just brought back into service?   :-/
spurno
  • torquay
Re: warning noise
« Reply #10 on: 10 September 2007, 16:07:48 »
no,bought car in april and it hasn't happened till now.had been laid up for about a year before i bought it though.
megaomega123
Re: warning noise
« Reply #11 on: 10 September 2007, 19:41:39 »
Following this thread, I have just gone to take a look at mine. When my alarm goes off, all that happens is the indicators flash. Not enough to deter a would be car thief.  I took out the sounder and then connected a standard speaker from the connector using speaker wire.
This time the alarm went of and the speaker cone moved with gusto. I then wired it to the car horns, which produced the same result. So by this theory I should be able to attach any speaker so long as it is a 12v amplified :question
Would this be a suitable replacement?
http://cgi.ebay.co.uk/NEW-CAR-ALARM-12V-SIREN-HORN-WARNING-VERY-LOUD-SMALL_W0QQitemZ140155367440QQihZ004QQcategoryZ75329QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
