Author Topic: Cuting out at junctions  (Read 4329 times)
markyp33
Re: Cuting out at junctions
« Reply #15 on: 11 September 2007, 14:37:19 »
There isnt any suction on the small breather pipe coming off of the rocker box, and therefore I need to clean it. I have removed the end off of the rocker box but cannot get to undo the clip at the other end. It said I had got to clean the jet too - so I started to loosen of the 19mm nut where the other end of the hose terminates - and water started leaking out!   Do I take it I just need to get longer pliers and remove the hose clip, and where is this jet? Sorry to be a nonce but Im not a great mechanic, but am on a really tight budget so would like to try and see this through as far as I can myself.
Thanks again to you all
Grumpy
  • Manchester
« Reply #16 on: 11 September 2007, 14:51:08 »
Have replied on your other thread.
