Author Topic: USING VECTRA ALLOY CAM-COVERS !!  (Read 2245 times)
v6venom
  • nr wareham dorset
  • banned due to bad trader references
« on: 11 September 2007, 21:56:02 »
As above has anybody changed to the alloy vectra cam-covers??
if so how did you go about the oil filler ??
any suggestions would be great  :y
cheers al :)
« Last Edit: 11 September 2007, 21:57:20 by v6venom »
    • 530D M Sport, 330i Coupe
Re: USING VECTRA ALLOY CAM-COVERS !!
« Reply #1 on: 11 September 2007, 22:05:06 »
A few have done it... you'll need a funnel with a long neck!
v6venom
  • nr wareham dorset
« Reply #2 on: 11 September 2007, 22:08:23 »
that i dont mind .......lol
so its deffo a case of fit straight on with a tweeked funnel should a top up be needed ??
appreciate the quick reply can crack on tommorow now as was jubious id have a prob ....
cheers al
PhilCavSRi130
  • Stone,  Staffordshire
  • GRIFFIN POWER!!
« Reply #3 on: 11 September 2007, 22:24:49 »
Iv'e changed to the veccy covers and yes they go striaght on without any probs.
As said filling oil is done by using a funnel.
v6venom
  • nr wareham dorset
« Reply #4 on: 11 September 2007, 22:35:39 »
if im thinking right it was yours i saw that made me presume was possible ....
if your smutty`s other half ??
thanks for the help guys much appreciated  :y
PhilCavSRi130
  • GRIFFIN POWER!!
« Reply #5 on: 11 September 2007, 23:00:59 »
Guilty as charged matey lol.... ;D
Only thing i will say is keep on top of the breathers as when using the plastic covers, they leak as the breathers get blocked. With the metal covers it will have to find an alternative route and as you drive a veccy too, you will know the crank seals go!!
« Last Edit: 11 September 2007, 23:04:34 by PhilCavSRi130 »
v6venom
  • nr wareham dorset
« Reply #6 on: 11 September 2007, 23:21:03 »
yep shall be a routine clean out  although hope to have the engine out over the winter and refit a tweeked 3 ltr ...   :y
thanks for the advice can get stuck in now .....
say hi to h for me  :)
atb al
« Reply #7 on: 12 September 2007, 08:42:46 »
Good luck with it...   ...as you have found out, own of those funnels with a flexi hose on bottom is probably worthwhile...
