Pages: [1] 2 3  All   Go Down
Author Topic: 2.5TD Head Gasket - Notches?  (Read 5520 times)
« on: 08 September 2007, 10:49:53 »
Seeing as whatever option I take, the head has to come off, I need to get a new HG.  Does anyone know where I can find the thickness of mine - I can't find these 'notches' anywhere (not that I know what they look like)?
Martin_1962
Re: 2.5TD Head Gasket - Notches?
« Reply #1 on: 08 September 2007, 12:07:07 »
Get the head off and measure tha gasket.
At least spares should  be available from a lot more places than some engines
Dazzler
  • Haverhill, Suffolk
« Reply #2 on: 08 September 2007, 16:08:29 »
Make your own marks for ease of reassembley and cable tie the top sproket to the chain...
« Reply #3 on: 08 September 2007, 20:08:39 »
You need the notches to be able to get the right gasket.  Now surely, even BMW aren't so stupid as to make those invisible??
Martin_1962
« Reply #4 on: 08 September 2007, 20:12:11 »
Take old one in and get the same?
hotel21
  • The Kingdom of Fife
« Reply #5 on: 08 September 2007, 20:16:16 »
No direct experience of these beasties, but others similar....  Apologies if you already know this....  :-[
The 'notches' should either be small peaks showing out of the edge of the head/block face towards the front (easy access) and to one side.  (dohh!!   :D)  Sometimes the sneeky beggars make them as valleys instead of peaks (prinking shears type effect) so that you are minutely looking for 'valleys' in the head/block join rather than peaks sticking out, if you follow.  Over time the dust/dirt/oil/crud fills these valleys so that they dissapear.
The peaks/nicks are intended as a means to ID the new gasket thickness in the packet rather than what size required on the original machine before stripdown.
Reason being that if a head is removed for machining, a correspondingly thicker gasket, as referenced from manuf manuals for orig thickness and tables including machining removed, is requested to maintain comp ratio.
As said, no experience of Beemer bits but played with assorted engines/piston compressors over the years.....
HtH
« Last Edit: 08 September 2007, 20:22:01 by hotel21 »
« Reply #6 on: 08 September 2007, 20:16:27 »
I cannot believe even BMW designers are that stupid.  I want one before I start stripping down - is that too much to ask?
hotel21
« Reply #7 on: 08 September 2007, 20:19:14 »
Why not speak to the friendly parts guy at the local helpfull dealership and view a new one and get a clue as to where to look on the head?
« Reply #8 on: 08 September 2007, 20:22:25 »
No dealer around here stocks them...
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #9 on: 08 September 2007, 20:37:11 »
No mention in TIS/EPC for either marque?
TuBy's new whipping boy.
« Reply #10 on: 08 September 2007, 20:42:23 »
yup, 2 or 3 notches. No clues to notch location.
Martin_1962
« Reply #11 on: 08 September 2007, 20:44:57 »
Land Rover?
BMW?
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #12 on: 08 September 2007, 20:45:43 »
Bugger.
« Reply #13 on: 08 September 2007, 20:56:05 »
Land Rover?
BMW?
no landie or beemer dealers for a good few miles round here.
Martin_1962
« Reply #14 on: 08 September 2007, 21:17:38 »
Land Rover?
BMW?
I'm surprised = living where you do that there aren't these dealers
Pages: [1] 2 3  All   Go Up
Page created in 0.312 seconds with 20 queries.
