Author Topic: climate control  (Read 4426 times)
miggy
climate control
« on: 01 September 2007, 17:16:09 »
I seem to have a problem with the CDX, the climate control works fine in the front of the vehicle but the rear seems not right.
When i have it set on say, 18 degrees, the front is nice and cool but the rear center vents are blowing very hot, if I turn up the heat the front blows cool but no change with the rear.
I remember reading something about this before on the forum.
Can anyone advise.
Thanks
Baron Von Spongebob
  • South Wales
  • Living the dream
Re: climate control
« Reply #1 on: 01 September 2007, 17:24:17 »
Can anyone advise.
Thanks
Miggy the Scarlet Pimpernel.. :D
Got it working i see.
Is the world ready for me..
miggy
Re: climate control
« Reply #2 on: 01 September 2007, 22:55:03 »
I think this post ref climate control should have gone into gereral help, could the admins help.
« Last Edit: 01 September 2007, 22:55:43 by miggy »
miggy
Re: climate control
« Reply #3 on: 02 September 2007, 17:13:36 »
Can anyone advise.
Thanks
Anyone had this problem before, looks like its a trip to Vx.
old cruiser
  • Slough
Re: climate control
« Reply #4 on: 02 September 2007, 18:00:03 »
You could try resetting the servos, by pressing AUTO & OFF buttons Simultaneously for Approx' 5 Secs and see if this sorts it.
Cheers Pete
Re: climate control
« Reply #5 on: 02 September 2007, 18:06:30 »
I think it should stay here - its a valid Omega Issue
miggy
Re: climate control
« Reply #6 on: 02 September 2007, 18:08:19 »
Cheers Pete
Thanks, thats the first thing I tried but it is still the same, maybe it needs re-gassing
miggy
Re: climate control
« Reply #7 on: 02 September 2007, 19:10:06 »
Just been reading a bit about air con, climate control, the script talks about air con rads and matrix.
Would that mean rads as the same as a rad on the car, but in a very smaller version.
Would that air con rad have coolant in it or gasses.
If it is coolant would it be on the same system as the main rad or would it be an independant system.
Your thoughts on this please.
Re: climate control
« Reply #8 on: 02 September 2007, 19:17:21 »
Few things...
The A/C gas (or lack of) won't make the system misbehave like yours - it will simply not provide chilled air.
There is one radiator (engine cooling) and one heater matrix, so again, not symptoms you describe.
I may need a little think on this one  :-/
miggy
Re: climate control
« Reply #9 on: 02 September 2007, 19:32:03 »
Few things...
Thanks TB, if no joy I will pop into Vx, better still I will contact the dealer I purchased it from last week, he gave me 12 months warrenty, if it had been something simple, I would have delt with it myself.
Re: climate control
« Reply #10 on: 02 September 2007, 19:32:11 »
wondering if the actuator ball joints have popped off the air distribution flaps....
miggy
Re: climate control
« Reply #11 on: 02 September 2007, 19:35:48 »
When I put the circulation to screen it does stop coming out of the rear vents, also if I put it to floor it stops coming out of the rear vents.
If it were the ball joints would it come out of the rear all the time.
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: climate control
« Reply #12 on: 02 September 2007, 19:37:34 »
Not that I have a clue what the problem is have you tried putting  the temp to hot and see what happens all around  :question
miggy
Re: climate control
« Reply #13 on: 02 September 2007, 19:42:54 »
Yes mate, when I put the temp to high, the rear stays hot but the front is very cold from the vents.
Its a brain teaser this one.
Re: climate control
« Reply #14 on: 02 September 2007, 22:31:44 »
Got to be the air distribution flaps have disconnected themselves from their servos...
If you were nearer, I'd get the Tech2 on it to see what it thinks its doing...
