Author Topic: paper clip test  (Read 1452 times)
batista
  • yardley wood birmingham
paper clip test
« on: 13 September 2007, 18:36:56 »
hello fello omegas,my v6 elite idles eratically.just done paper clip test and code fault 59 is lit up,saying inlet manifold senor high voltage/low voltage.what does this mean,pardon me for being thick,is it knackered or something else wrong.any comments greatly appreciated. ;)
hotel21
  • The Kingdom of Fife
Re: paper clip test
« Reply #1 on: 13 September 2007, 20:15:02 »
Sounds like the front or rear multiram connector is unplugged?
If you look at the very front of the engine, under the two large air inlet pipes to the large plenum on top of the engine, you will see an actuator with an electrical plug.  Likewise, another to the rear right of the plenum.  Ensure both clean and connected but I could be way off the mark.  Someone else may be able to confirm or assist.....   :y
« Last Edit: 13 September 2007, 23:40:48 by hotel21 »
JasonH
Re: paper clip test
« Reply #2 on: 13 September 2007, 23:39:01 »
I think 59 is the connector on the back of the plenum - the other part of the multiram.
Just underneath the big aluminium lump on the top of the engine at the rear.
