Author Topic: Central Locking  (Read 1994 times)
M-Tek Performance
  • Hull
Central Locking
« on: 17 September 2007, 15:02:48 »
The central locking works from the remote and the key.
however,  from the remote it doesnt always lock the drivers door, and sometimes it does.
also, had to disconnect the passenger side CDL as it wouldnt open at all with the CDL connected - will this need a new module??
will the drivers side be a new module?
Dazzler
  • Haverhill, Suffolk
Re: Central Locking
« Reply #1 on: 17 September 2007, 15:12:46 »
Check the connections first, i had a similar problem which turned out to be a dodgey connection.
M-Tek Performance
  • Hull
Re: Central Locking
« Reply #2 on: 17 September 2007, 15:16:38 »
This has been checked and still at fault..
Mike Collins
  • North of Bristol
Re: Central Locking
« Reply #3 on: 17 September 2007, 17:27:00 »
Is the door lock motor being driven, can you see the pin move down?
If not it's possibly the motor, if you remove and dismantle it you will find two microswitches inside.
One will probably have high resistance across the NC contacts, easy and inexpensive to replace the switch.
Danny
  • Wigan, Greater Manchester
Re: Central Locking
« Reply #4 on: 17 September 2007, 18:23:36 »
yep possible motor goosed
i had a problem with mine not UNlocking but it was due to cold weather, but again only the drivers door
