Author Topic: Clicking Noise  (Read 2383 times)
star_whites
  • Rotherham
Clicking Noise
« on: 16 September 2007, 23:04:23 »
Does anyone know how bad or easy a job it is to remove and refit the injection rail and all other items on it. I have a clickng noise from the injection rail (certain its not the tappets) and Im guessing that its an air leak.
Any ideas anyone?
On holiday next week so figured I would order the seals this week from vx and have a go myself next week.
Re: Clicking Noise
« Reply #1 on: 16 September 2007, 23:09:17 »
I know nothing .. but I've read quite a lot ... :)
And if I recall correctly, the cam cover gasket replacement involves removing the fuel rail ... so by only doing half of this :
http://www.omegaowners.com/forum/YaBB.pl?num=1152564281
you should be OK  :)
An expert will pass by shortly and correct all my errors . :)
Dazzler
  • Haverhill, Suffolk
Re: Clicking Noise
« Reply #2 on: 17 September 2007, 09:00:08 »
Yes, injector rail is easy to replace. Like already said just follow some of the above guide ;) Ask in parts wanted for a 2nd hand set.
Dazzler
Re: Clicking Noise
« Reply #3 on: 17 September 2007, 09:00:55 »
Just to note that all injectors make a slight ticking noise.
Re: Clicking Noise
« Reply #4 on: 17 September 2007, 09:44:47 »
Do you have this problem when the engine is cold or everytime ?
star_whites
  • Rotherham
Re: Clicking Noise
« Reply #5 on: 17 September 2007, 18:03:21 »
The noise is there all the time, as if something hasnt been sealed properly.
star_whites
  • Rotherham
Re: Clicking Noise
« Reply #6 on: 17 September 2007, 18:04:51 »
P.S the instructions above are for a V6, surely these are not the same for a 2.0l
Dazzler
Re: Clicking Noise
« Reply #7 on: 17 September 2007, 18:08:28 »
star_whites
  • Rotherham
Re: Clicking Noise
« Reply #8 on: 17 September 2007, 22:12:26 »
Guessing by the sad face that the instructions are not the same, so it looks like I will be relying on the dreaded haynes manual. It never actually states what you need to know  :-/
