Author Topic: Headlining Removal  (Read 1474 times)
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Headlining Removal
« on: 18 September 2007, 17:11:39 »
How easy is it to remove the rear headlining in an estate?
I am sure that to replace the sealing gasket at the base of the Bee-sting radio antenna I will need to drop or remove the headlining
Has anyone any experience of doing this?
IW
Dazzler
  • Haverhill, Suffolk
Re: Headlining Removal
« Reply #1 on: 18 September 2007, 18:30:24 »
As far as i recall the headliner is one piece front to back. Do not try and just pull down the back as it is a hard headliner so if you bend it, it will crease and thats game over.
Basically you have to remove all the handles and door rubbers, lights etc..... and then it will come down.
