Author Topic: Problem after rocker gaskets?  (Read 1590 times)
omegalord
« on: 18 September 2007, 22:38:32 »
Done the rocker gaskets , all running mint now apart from the hbv problem i now have
My question is....
When i start the car up first thing , it doesnt tick over at 1100rpm until warm anymore and if i rev it to about 4-5k rpm and lift off the accelerator , as the revs are coming down it pops and farts sometimes.
Any ideas?
Matt   :-/
IrmscherKris
  • Manchester
  • banned due to bad trader references
Re: Problem after rocker gaskets?
« Reply #1 on: 18 September 2007, 22:46:15 »
Did you put the leads back on correctly?
Any oil in the plug wells?
EML going out ok?
omegalord
« Reply #2 on: 18 September 2007, 22:48:30 »
eml light is on , says its a plug at the back ram , it is plugged in but rams havent worked since i had it. There is still a bit of oil in the wells but couldnt clean it out any better then i did
Matt
IrmscherKris
  • Manchester
« Reply #3 on: 18 September 2007, 22:56:15 »
You won't like this....
Strip down the plennum so you can access the back of the inlet and disconnect and reconnect all the plugs again - it's poss you have disturbed something when putting plennum back on.  :y
omegalord
« Reply #4 on: 18 September 2007, 23:00:03 »
I dont mind taking the plenum off , not a hard job.
I might actually take the plenum off and do the hbv valve while im there.
Matt
Page created in 0.242 seconds with 20 queries.
