Author Topic: Thanks for help no more crecking door  (Read 1375 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« on: 19 September 2007, 09:21:44 »
Thanks very much:   It was the nicest trip I have had to Vauxhall spares department ever. After a read last week of how to replace the Bush on the drives   door when to vau to Saturday a spent the total sum of 50p for two new Bush,s . Took 5 mins to fit thanks to the how to and no more creaking. :y
All give the Breathers a good clean out BUT this time I also cleaned the Y shaped part of the system the one at the back on the engine [ sorry don't know the name.of it]. There was so much muck in it. When all do the engine seem to run a lot better and it starts we a nice big ROAR. Thank for all the help and the Great How To,s.
Steve.  ;)
« Last Edit: 19 September 2007, 09:24:31 by SP_3.2 »
Re: Thanks for help no more crecking door
« Reply #1 on: 19 September 2007, 09:23:26 »
The easy fixes to the annoying problems are soooo satisfying :y
SP_3.2
  • Leicester
« Reply #2 on: 19 September 2007, 09:32:45 »
So true just out of intrest what is the name of the Y shape part at the back of the breather system and is it best to remove it when cleaning. I could not get to it to remove so just used  lots of carb cleaner and a coat hanger. Is that ok.
Thanks
« Reply #3 on: 19 September 2007, 10:02:32 »
Hose, Connecting, Cylinder Block Ventilation
and no, thats not OK - in affect you have sprayed carb cleaner into the engine oil (and possibly a load of that gunk), so that probably should be changed now.  It needs to come off to do properly.
  • Online Online
    • 530D M Sport, 330i Coupe
« Reply #4 on: 19 September 2007, 10:19:57 »
SP
If you get really stuck trying to get that Y pipe off then give me a shout and i'll give you a hand. It's awkward but possible!
SP_3.2
  • Leicester
« Reply #5 on: 19 September 2007, 11:13:30 »
Thanks for that i will take it off next time.Thanks of the offer of help VXL. Will give you shout we next doing the job will have a cup of tea readly for you :y
