Author Topic: Split pipe  (Read 2513 times)
AndersH
  • Poole
Split pipe
« on: 06 August 2007, 21:17:07 »
Hi all, I was just topping up my screenwash and noticed that I had a split in one of the pipes - the one that is disconnected in this photo:
I have bodged it with some tape at the moment but what I wanted to know was, what problems may this have caused? would it have affected mpg at all? as I think mine has been bad of late.
Also, Is there a part number for this pipe or a description so I could get a replacement?
Thanks!
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Split pipe
« Reply #1 on: 06 August 2007, 22:03:14 »
Personally I would have thought it would make a difference......
this link will tell you what pipe is for where, sorry can't be any more help than that mate but someone will be a long soon :y
http://www.omegaowners.com/forum/YaBB.pl?num=1152598350
razzo
  • Crapital
    • 97 3.0 Elite
Re: Split pipe
« Reply #2 on: 06 August 2007, 22:15:06 »
Don't know part no. but think pipe goes here  www.infohitsystems.ltd.uk/Gallery/dirwrap_photo.sh?rt=wrap&path=Car/P1010040.JPG
Re: Split pipe
« Reply #3 on: 07 August 2007, 08:14:28 »
That will give quite a hefty air leak and as a result a reduced inlet vaccum.....which will affect economy
Kaycee
  • Doncaster
Re: Split pipe
« Reply #4 on: 07 August 2007, 09:32:41 »
ive had a few split pipes over the last couple of years rather than drag em out to see were they going i just cut of split end and extend it with a bit of brake pipe and rubber on end much quicker than ragging all the pipes out works for me
There is a tide in the affairs of man if taken at the flood will lead on to greater things
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Split pipe
« Reply #5 on: 07 August 2007, 09:34:40 »
that seems to be a common one for splits, just pull it firmly but gently and cut th end off it ( providing its not too long a split...
AndersH
  • Poole
Re: Split pipe
« Reply #6 on: 07 August 2007, 11:32:43 »
Thanks for the replies, I'm not sure if there's enough left to cut the end off, the split is around an inch long. Although if I route it slightly differently I may be able to do that. I have to get a few parts from the dealer anyway so I thought I'd try to get a new one but am unsure of a part number or a decent desription.
AndersH
  • Poole
Re: Split pipe
« Reply #7 on: 19 September 2007, 12:56:12 »
I ended up cutting the pipe and reattaching, but a couple of weeks later has split again... I have cleaned the breathers in between this happening, I couldn't get the other end of this pipe off so left it  :-[ I may have to cut it off the other end and get a new one - would this be the best thing to do?
