Pages: 1 [2] 3  All   Go Down
Author Topic: petrol pump failure  (Read 12285 times)
wizzy_michael
  • wisbech, cambridgeshire
Re: petrol pump failure
« Reply #15 on: 07 September 2007, 20:15:20 »
when i turn the ignition on should the orange light with the engine symbol on it come on and then go out when it starts
hotel21
  • The Kingdom of Fife
« Reply #16 on: 07 September 2007, 20:27:02 »
yup
wizzy_michael
« Reply #17 on: 07 September 2007, 20:30:49 »
oh dear, mine doesnt :( any ideas on this
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #18 on: 07 September 2007, 20:42:19 »
Doesn't what, come on or go out?
TuBy's new whipping boy.
wizzy_michael
« Reply #19 on: 07 September 2007, 20:51:37 »
it doesnt come on
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #20 on: 07 September 2007, 21:01:44 »
Duff bulb would be my guess.
hotel21
« Reply #21 on: 07 September 2007, 21:04:46 »
Possibly previous owner removed it to cover a fault.....   :-X
wizzy_michael
« Reply #22 on: 07 September 2007, 21:08:50 »
and i bet this is the bulb that flashes on the paperclip test.what about these code readers you can get, a tech 2 reader, are they any good  (seen on ebay)
wizzy_michael
« Reply #23 on: 07 September 2007, 21:11:31 »
im sure it used to come on
magnul
  • Trondheim, Norway
« Reply #24 on: 07 September 2007, 21:18:09 »
The El cheapo tech2 only works from -97 and on, so it probably won't work on your car. Just take out the instrument panel and replace the bulb. Replace all others bulbs there while you have it off.
wizzy_michael
« Reply #25 on: 07 September 2007, 21:32:27 »
lets go back a few posts to the suggestion of code 19 stored on ecu. how does this affect the petrol pump as i cant here it when i turn on the ignition, there was once a small whirring till the pressure built up. how do i rectify code 19. trouble is i dont want to make the vauxhall garage any richer
wizzy_michael
« Reply #26 on: 07 September 2007, 21:41:41 »
any idea where i can get a proper reader? going to have a beer now :) and call it a day, will check bulbs tomorrow.
2001CatOwner
  • Across the Pond (Wisconsin)
« Reply #27 on: 08 September 2007, 01:02:52 »
« Reply #28 on: 08 September 2007, 07:53:34 »
1) Sort the bulb....
2) Do the paper clip test to see what codes are stored.
For info, code 19 relates to crank sensor, if no crank signal is seen then you get no spark or injection operation.
And the cheap tech 2 will wpork on all the Omega cable throttle V6 power plants from 1994 onwards.
wizzy_michael
« Reply #29 on: 08 September 2007, 08:35:08 »
thanks, gonna have breakfast then gonna get on with it :y
Pages: 1 [2] 3  All   Go Up
