Author Topic: Is it possible to retrofit...  (Read 1611 times)
« on: 19 September 2007, 22:52:08 »
A torx headed sump plug, with a rubber washer, onto an earlier Omega that's always had a copper washer?
hotel21
  • The Kingdom of Fife
Re: Is it possible to retrofit...
« Reply #1 on: 19 September 2007, 22:54:32 »
Never tried it but do not see why not.
Do you have access to both to compare shape of metal surrounding the hole?
« Last Edit: 19 September 2007, 22:54:57 by hotel21 »
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #2 on: 19 September 2007, 22:57:50 »
I'd ask JamesV6CDX ... he's always playing about with sump plugs ;D
I assume you mean a torx one of a Veccy  ...  it's worth a try, but just insert it by hand to make sure the threads are the same.  The worst that can happen then is that it leaks, in which case you have your answer.  :-?
« Reply #3 on: 19 September 2007, 23:07:31 »
It just seems like a good idea to fit one with the rubber washer if possible, as, requiring a much lower torque value, the thread is less likely to strip  ::)
The threads are the same - M14, with a 1.5mm pitch..
hotel21
« Reply #4 on: 19 September 2007, 23:11:27 »
The copper washer should be annealled and thus be soft.  Harder than the 'O' ring obviously, but still soft enough to be marked by a thumb nail.  If its re-used without annealling, then it will probably leak.
Copper washer needs a flat surface to mate against whilst the 'O' ring may well be fed into a slight taper so that its compressed both across the flats as well as into the thread, hence the compare surfaces query.
Same thread is a no brainer...   :y
« Reply #5 on: 19 September 2007, 23:18:11 »
From memory mine has a torx plug with an "O" ring. The "O" ring fits into a groove on the plug face and seals against a flat surface on the face of the sump so I'd say it's a go'er providing the surface of the sump hasn't been chewed up.
    • 530D M Sport, 330i Coupe
« Reply #6 on: 19 September 2007, 23:20:50 »
Yep, Torx on mine as well.
« Reply #7 on: 20 September 2007, 01:55:56 »
I feel a test coming on :)
