Author Topic: Door Strap Repair  (Read 5175 times)
Jim
  • Glasgow
    • Irmscher 3.2 V6 Elite
    • My Vauxhall Omega's
Door Strap Repair
« on: 19 September 2007, 22:23:40 »
Tomorrow I'm going to repair the ripped out door strap tear on my drivers door (got the plates/repair kit from VX) but the door has no strap mechanism but I have a spare which I removed from a passenger side door, on the door strap there is an R on one side and a L on the other, is it the same part for both sides, can I use the part from the passenger side door to repair the drivers door by turning it upside down.
Cheers Jim
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Door Strap Repair
« Reply #1 on: 19 September 2007, 22:36:28 »
not sure but you can let me know as my estate needs the same repair... :y
Jim
  • Glasgow
« Reply #2 on: 19 September 2007, 22:37:58 »
Will do mate, it's the Black mv6 I'm repairing
hotel21
  • The Kingdom of Fife
« Reply #3 on: 19 September 2007, 22:42:56 »
A front strap does either L or R at the front only.  Does not fit the rear.
and vice versa, rear cannot fit on the front.
As I recall, it cannot simply be turned upside down as there is a clearance issue wthin the door itself.  You need to turn the check strap only, leaving the plate with figure 8 spring, roller etc the same way up.
The stamped R or L goes uppermost and can be swapped from side to side by simply placing the figure of 8 spring portion in a vice, using a lever (screwdriver?) to remove the tension in the spring affair then turn the check strap rod the other way up.
If you are stuck, I have a spare in the garage and will take a few piccys in the morning showing what I mean.   :y
« Last Edit: 19 September 2007, 22:44:48 by hotel21 »
Paul M
  • Edinburgh
« Reply #4 on: 19 September 2007, 22:43:20 »
Pretty sure they're the same both sides so you can just turn em upside down, you probably have to take the check strap out of the mechanism and rotate that, but it's really easy to do with it removed from the door.
Markie
« Reply #5 on: 19 September 2007, 22:45:58 »
ooooh an all Jock thread.....Jim do you have the part number of the repair kit? :y
Jim
  • Glasgow
« Reply #6 on: 19 September 2007, 22:47:59 »
I'ii give it a go in the morning only problem is I don't have a vice :'(
hotel21
« Reply #7 on: 19 September 2007, 22:50:25 »
Theres nothing fancy in the kit, other than a couple of mild steel plates and slightly lengthened screws.  After seeing it, its probably something that could be knocked up with in most garages and save a few squids....
Jim - you fancy measuring the sizes of the plates including holes before you fit them and posting them up?
Jim
  • Glasgow
« Reply #8 on: 19 September 2007, 22:51:00 »
Yep, I got it in the maintence section cheers.
I painted the repair plates today so I'II let the paint harden over night :y
Thanks to all the Jocks, Freedom!!!!!!!!!!!! ;D ;D
Jim
  • Glasgow
« Reply #9 on: 19 September 2007, 22:52:04 »
Will do Mate :y
hotel21
« Reply #10 on: 19 September 2007, 22:52:35 »
You got a pair of size nines on the end of your legs?  Need one screwdriver in one portion, held down with your boot, lever in the other portion, pull up with one hand to releive tension, use the other to turn the strap., then relax...
They teach you what kind of fieldcraft these days?  What happened to improvise, adapt, overcome??   ;D
Jim
  • Glasgow
« Reply #11 on: 19 September 2007, 22:55:36 »
I'm only a size 7 is that OK ;D ;D
Remember I'm a driver if I have to get out of the car, I can't be arsed ;D ;D
hotel21
« Reply #12 on: 19 September 2007, 22:58:50 »
Size 7?  Oh, thats OK, you have the added advantage of a much lower centre of gravity as well.   ;D
Give me a call if your stuck....   :y
Jim
  • Glasgow
« Reply #13 on: 19 September 2007, 23:00:11 »
Will do mate, cheers :y
Markjay
  • London
« Reply #14 on: 19 September 2007, 23:05:27 »
I can't remember if I added this to the Maintenance Guides sections, but here it is anyway... hope this helps.
« Last Edit: 19 September 2007, 23:07:54 by markjay »
Alas, no more Omegas....
