Author Topic: 2.5 Auto Gearbox Leak  (Read 1777 times)
keno
« on: 20 September 2007, 21:02:33 »
Hi All,bit of a cheek really,i done own an omega but am working on one,came to me with a serious oil leak from the bell housing,definitly tramsmission fluid,took out box and replaced torque converter oil seal,put it back together and still pi**ing out,took it out again,thought i might have damaged seal putting it in,it was ok but i put in another new one,still leaking,any help????? please
hotel21
  • The Kingdom of Fife
Re: 2.5 Auto Gearbox Leak
« Reply #1 on: 20 September 2007, 21:05:39 »
Sorry, not my area of expertise.  Try the search function under the logo at the top of the page.  You will no doubt get a few ideas with the results.   ;)
Good luck with the repair...  :y
« Reply #2 on: 20 September 2007, 21:38:49 »
Is the leak coming from the torque converter seal? Or could it be coming from elsewhere?  Mine was leaking from a pipe, but it ran done bellhousing...
keno
« Reply #3 on: 20 September 2007, 21:51:24 »
It is coming from inside the bellhousing,but i dont think its from the seal but i couldnt see anywhere else inside that could leak,unless it has a fracture in the housing,but its not noisy and it still changes gear ok..
« Reply #4 on: 20 September 2007, 21:55:18 »
Hmm, not sure then, unless coming through one of those bolts that hold bellhousing on.  Or leak in TC itself (unlikely)
« Reply #5 on: 20 September 2007, 21:59:18 »
Mine leak on the left side (passenger for your country) from a socket..But problem is whole socket needed to change not the gasket alone..Hope this helps..
keno
« Reply #6 on: 20 September 2007, 22:04:09 »
This is coming from inside the bellhousing, :(,outside is dry,leaks when car is running only.
