Author Topic: Vacc pipe size  (Read 1660 times)
Vacc pipe size
« on: 20 September 2007, 21:58:30 »
Anyone know what size the vaccum hoses are, with the rubber bits on the end of them? Looking to buy one way valves.. so need to know diameter :y
PhilCavSRi130
  • Stone,  Staffordshire
  • GRIFFIN POWER!!
Re: Vacc pipe size
« Reply #2 on: 21 September 2007, 19:17:25 »
Just one question!
Why do you want to fit these???
Re: Vacc pipe size
« Reply #3 on: 21 September 2007, 20:19:08 »
I've just purchased a simelar one - this seller had none left.
It's to replace the one way valve that fails :)
Re: Vacc pipe size
« Reply #4 on: 21 September 2007, 21:17:15 »
The vac tank on the front inlet track that works the multirams has a one way valve in it that fails, using these cheap valves is a way of repairing the fault without replacing the whole tank.
omega18
  • Morecambe
Re: Vacc pipe size
« Reply #5 on: 21 September 2007, 21:36:36 »
I replaced the whole tank with one from autovaux and either that valve was knackered or non existent as it didn't work either, they sent another replacement that also has no (or is broken as well) one way valve.  >:(
Page created in 0.225 seconds with 20 queries.
